Moving fuel filter
Old Nov 11, 2010 | 07:34 PM
tinctorus's Avatar
Default Moving fuel filter
Hey guy's, I am getting ready to start my direct port nitrous setup but want to do a few things first to clean up the engin bay a little bit
I would like to get rid of the fuel filter that is mounted on the fire wall and do an inline fuel filter, I assume since it is just rubber line going to the fuel filter from the pump I could just use a aeromotive or jeg's or one of the hundreds of other inline fuel filters and mount it underneath the car in a safe place right??
Also right now I have a fuel pressure gauge that the previous owner mounted on top of the fuel filter that I would like to keep, Can I just move the gauge closer to the rail with something like a T fitting right at the fuel rail OR should I tap the rail??
Actually now that I think about it there is already an aftermarket fuel rail on the car and at the end of it is a screw on cap to release pressure from the system should I need to work on it, Can I just get a fitting to go on the end of that and mount the gauge there or will I not get a proper reading since it will be at the end of the rail furthest away from where the fuel comes in???
What do you guy's do when you install a fuel pressure gauge inside the car,"IE" where do you mount the sender???
Any help is appreciated
Thanks guy's
Mike G
Old Nov 27, 2010 | 06:10 PM
tinctorus's Avatar
Default Re: Moving fuel filter
Jeez luiz NOBODY has any thoughts or opinions on this??
Old Dec 10, 2010 | 09:04 PM
tinctorus's Avatar
Can someone just let me know if my thinking is correct with just doing an inline fuel filter along with the associated steel braided line and A/N fittings??
Old Dec 11, 2010 | 08:53 AM
fcm's Avatar
fcm
Old Fart
Yes you can use an inline filter.
Yes, get a fitting for the fuel rail and install the FPG on the rail.
Where a sending unit, [or FPG] is mounted depends on what FP you want to read, fuel pump pressure, or fuel rail pressure, [before or after FPR] . 94
Old Dec 11, 2010 | 09:01 AM
tinctorus's Avatar
I would think that fuel rail pressure would be more benneficial to monitor that pressure right at the pump right?
Old Dec 11, 2010 | 09:18 AM
thegatekeeper14's Avatar
we sell these.
pm me.
cmwalker
Jul 12, 2012 12:10 AM
LS-VTEC-TURBO-EF9
Jun 19, 2009 06:26 AM
Fuster_Cluck
Aug 27, 2007 02:51 AM
SiYouLater
Apr 14, 2007 11:42 AM
LudEcrous
Feb 7, 2004 11:39 AM
