what do i do bout 3 wire iacv to a 2 wire iacv
Old Nov 11, 2010 | 02:47 PM
h22accord101's Avatar
Default what do i do bout 3 wire iacv to a 2 wire iacv
okay i am putting a ls swap in a 1996 honda civic dx which i am doing the obd2 to obd1 conversion harness using a chipped po6 ecu. question i have is how can i convert the 3 wire iacv to a 2 wire iacv caus eth stock y7 had the 3 wire iacv and the 1.8 dohc ls has the 2 wire iacv and the ls is also out of a 97 acura integra hopefully someone can help me out thanks
Old Nov 11, 2010 | 03:41 PM
Trey's Avatar
25 Year Member
Default Re: what do i do bout 3 wire iacv to a 2 wire iacv
You can thank Katman...
OBD2a (the one you need):
Obd2b (for reference):
Old Nov 11, 2010 | 04:56 PM
ok then what about the plug ima have to cut the 3 wire plug of and wire in the 2 wire are they color coded cause i am guessing the orange wire u wont use what bout the other 2 how will i know which one goes to which
Old Nov 11, 2010 | 04:59 PM
and if i do the instrutions above itll work also with the obd2 to obd1 harness
Old Nov 11, 2010 | 05:00 PM
Trey's Avatar
25 Year Member
Scan down for the IACV info... I don't think you have to do the pin swap from my post above AND the plug swap below. All I did was swap the plugs and that was it.
Old Nov 11, 2010 | 05:02 PM
ok but the ls doesnt have a 3 wire iacv it has the 2 wire plug like the y7 its on the tb and on the ls its on the intakemanifold and the plugs are diff so do i not plug it up at all
Old Nov 11, 2010 | 05:04 PM
i am useing the y7 harness in the 97 dx sry didnt say that my bad
Old Nov 11, 2010 | 05:07 PM
beleave thatll do it man thanks for the help
Old Mar 3, 2015 | 12:21 PM
Angel420's Avatar
Do I still have to do the pin out if i got a jumper harness i did a swap in my ek sohc to dohc and had to convert IACV plugs witch i did just neede to onow if i have to do the pin out aswell
Old Mar 3, 2015 | 12:44 PM
Former User's Avatar
Please read the thread carefully and check the FAQs sticky. If you have a specific question thereafter, create a thread.
Chaosgrunt
Mar 13, 2019 06:23 PM
youryanyou
Feb 9, 2011 12:43 AM
three pac
Oct 22, 2010 01:53 PM
hotimportcrx
Feb 6, 2006 11:45 AM
GDM Z28
Nov 4, 2004 04:08 PM
