Code 43 on 95 Civic
Ok how can i fix this code i heard is one of the worst codes on the honda thing i know a lot of honda but this code its pissing me off my car is a 95 civic with the d16z6 engine rebuild but that code is pissing me off what could it be or what should i look for. no mods at all
WELL I DONT KNOW THATS THE WAY I BOUGHT IT SO I DONT KNOW IF ITS THE SAME WAY MY CAR IS GOING TO RESPONSE OR IT NEEDS MORE POWER I DONT KNOW BUT ILL CHECK THE O2 SENSOR HOW CAN I CHECKED IT
OK I JUST DISCONNECTED IT AND PLUG IT BACK IN I CHECK THE CODES AND NO CODES WHERE BLINKING MY CHECK ENGINE LIGHT WAS ON AND MY SRS START IT BLINKING AND NEVER STOP ( I PLUG THE PAPERCLIP TO THE LITTLE CONNECTOR BELOW THE GLOVE COMPARTMENT
The SRS light blinks an SRS code with the service connector jumped when there is an airbag circuit problem.
Now drive the car to see whether code 43 returns.
ok my srs light blinks and dont stop when i jumped the service connector to check my ecu. and my car still turns off by itself everytime i press the gas pedal and when is release it shuts off so i need to press the gas pedal all the time even to brake or it will turn off and i cant floor it once in a while cuz it wont rev so i need to press the gas little by little until i cross the 1200rpm range but that happens once in a while
ProLineDesigns
Mar 28, 2006 05:20 AM
