Now I'm down to 22 MPG out of my HF...
Old Nov 11, 2010 | 11:00 AM
ED94LIFE's Avatar
Default Now I'm down to 22 MPG out of my HF...
I have a 91 CRX HF with the D15B6 all stock besides a header, test pipe and a 2.5 inch catback exhaust. I have done a tune up on it that consists of plugs, wires, cap, rotor, and fuel filter. Just for ***** and gigs I unplugged the O2 senser to see if it would through a code, but no CEL, I don't know what else I could do besides a new O2 sensor. Any help would be GREATLY appreciated, thanks in advance guys!
Old Nov 11, 2010 | 11:31 AM
That EF's Avatar
Default Re: Now I'm down to 22 MPG out of my HF...
pull the head off. i bet there is **** all over your pistons. i get 36mpg on my a6.
Old Nov 11, 2010 | 12:03 PM
ED94LIFE's Avatar
I can't really do any type of work like that bc this is my daily and I don't have any other transportation.
Old Nov 11, 2010 | 12:29 PM
That EF's Avatar
thats weird how you get 22mph. i honestly couldnt think of what it could be. maybe try cleaning your injectors?
Old Nov 11, 2010 | 01:25 PM
ED94LIFE's Avatar
Do you think an additive could do that?
Old Nov 11, 2010 | 01:31 PM
1994hondaprelude_dude's Avatar
this stuff does wonders it cleans out your injectors and stuff, just put it in your gas tank with a full tank of gas and I usually get 2-5 mpg better. Plus i believe it makes my car run a little better.
Old Nov 11, 2010 | 01:33 PM
ED94LIFE's Avatar
I'll give that a try, thank you!
Old Nov 11, 2010 | 03:06 PM
bfatdaintegra's Avatar
maybe ur intake manifold is all gummed up try takin it off and clean that thing out with carb cleaner to the throttle body too put new gaskets of course and check lil things like timing and set ur idle and that will prolly cure that right up try it and let me know,im from milwaukee i travel to green bay to do work for a guy so i cant do some work for u if need be
Old Nov 12, 2010 | 05:46 AM
Laserjock's Avatar
Test your PCV valve. It will move freely when you shake it or if you blow it from one side, it will open but stay close on the opposite end.
Or test your injectors. One may be sticking open dumping fuel
Old Nov 12, 2010 | 05:58 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Also check air system... good air filter, clean, etc...
New O2 sensor is cheap enough if you don't know when it's been done last. Check wiring if disconnecting isn't throwing a cel.
Old Nov 12, 2010 | 01:19 PM
ED94LIFE's Avatar
The air filter is brand new, the o2 sensor has 10,000 miles on it(previous owner told me)
Old Nov 12, 2010 | 06:12 PM
vg_Ace's Avatar
i wouldn't try any fuel injector cleaner. Consumer Reports have tried just about every one on the market and all of them don't do much to improve mpgs that a simple tuneup wouldn't fix.
If I were you I would replace your 02 sensor. If it is bad it might be making your car run way rich which would cause the mpgs to go down obviously.
I have the same engine. I can't think of anything else that would be causing you to get such bad mileage.
Old Nov 13, 2010 | 02:04 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Start with the easy stuff. Lift the car and make sure the wheels spin freeely.
I would suspect the injectors are flowing too much or even leaking internally.
neozero999
12
Aug 18, 2016 06:48 PM
sepheroth
46
Aug 16, 2010 02:14 PM
vtecn8ive
51
Feb 19, 2008 11:22 PM
wu tang
Aug 21, 2003 03:38 PM
jdwebmaster
12
Aug 13, 2003 06:17 AM
