Ok. New ECU in...But it Throws Code 5???
Old Sep 21, 2002 | 02:20 PM
SilverEk3dr's Avatar
Default Ok. New ECU in...But it Throws Code 5???
I got my 96 p13 in and wired all up. I reset me ecu and start the car and it seems to be missing/running a little rough when reved to 3000rpm. It eventually smoothes out after a couple seconds. Then after a minute or two my CEL will come on and it is throwing code 5(map sensor Too high/too low). Whats the deal? I went over my wiring for the map sensor and all is correct. I check my lines for vacuum leaks, and even reset my ECU again, and it continues to do it.
Any Ideas???
Thanks, Mark
Old Sep 21, 2002 | 04:55 PM
carolinaACCORD's Avatar
Default Re: Ok. New ECU in...But it Throws Code 5??? (SlvrEj6Dx)
if you have a vacuum pump, apply vacuum to MAP, up to 30in/hg, it should read 5V
on a multimeter.you'll have to backprobe the harness to check it.
Old Sep 22, 2002 | 09:28 AM
ViZ's Avatar
ViZ
Default Re: Ok. New ECU in...But it Throws Code 5??? (carolinaACCORD)
what year is your engine because 96 is odb2 where the 92-95 is odb1
Old Sep 22, 2002 | 10:07 AM
Default Re: Ok. New ECU in...But it Throws Code 5??? (ViZ)
my engine is a 99, and my ecu is a 96 p13 (OBD2)..... my car idles all messed up (bouncing idle). But after the cel comes on it stops doing that. I cant seem to figure it out. Also when I drive it with the CEL on it hesitates until 4500 and then it takes off (even under light throttle)
Its not the sensor that is bad....cuz I replace it with the one from my civic and it did the same thing.....
Mark
[Modified by SlvrEj6Dx, 7:10 PM 9/22/2002]
Old Sep 22, 2002 | 07:42 PM
satan_srv's Avatar
The ECU is expecting 310-340cc injectors (92-96 H22A1). The 99 H22A4 has 270??cc injectors so you could be supplying to little fuel and the knock sensor is kicking in? Just a thought.
kacheoh
Sep 19, 2009 11:54 PM
HeedLessInc
Dec 27, 2006 10:25 PM
vietnamese0utlawz
Sep 19, 2006 11:38 PM
GSRwBOOST
Jul 12, 2001 06:07 AM
