1995 GS-R 4dr and Special Edition exhaust interchangeable?
Old Nov 11, 2010 | 08:48 AM
EFboosted's Avatar
Default 1995 GS-R 4dr and Special Edition exhaust interchangeable?
I found a catback exhaust system that I really want for my 95 GSr 4dr. The seller carries it for the special edition 4dr for the same year. Are there any differences between the exhausts of these two models?
Old Nov 11, 2010 | 09:00 AM
sixfourkiller's Avatar
Default Re: 1995 GS-R 4dr and Special Edition exhaust interchangeable?
its sure be the same, it should bolt right up. the only differents exhaust are between the 2dr and 4dr and that the length of the exhaust.
Old Nov 11, 2010 | 09:12 AM
Sumslapper's Avatar
Year 3030
DOES NOT FIT. Type R, ls, rs, gs, s-e all are interchangeable being they have the same header length. 94-99 gsr's header is about 6 inches to short. Only the 00-01 gsr's are the same lengthe as Type R, ls, etc..
Basically the exhaust will be 6 inches to short where it bolts up to the cat unless you have a aftermarket header.
Old Nov 11, 2010 | 11:46 AM
EFboosted's Avatar
I plan to get an aftermarket header to go with the exhaust. My stock setup is rusted out and I need a replacement for the whole thing.
Old Nov 11, 2010 | 07:38 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
95 GS-R 4-door and 4-door SE had different part numbers on the exhaust pipe, so it might not work.
Old Nov 12, 2010 | 11:15 AM
2kdb8's Avatar
i have a 2000 4dr gsr and when i ordered my greddy sp2 catback they didnt have a listing for gsr so i ordered one for an ls and it fit.
19integra94
Apr 16, 2009 08:24 AM
94 IntegraLS
Mar 29, 2007 02:55 PM
NaCk3m
May 30, 2006 04:27 PM
rex_racer728
Mar 24, 2006 09:09 PM
H22A_HB
Nov 11, 2004 08:21 PM
