Eliminating Sunroof
Old Nov 11, 2010 | 01:35 AM
1.8EG-T's Avatar
Default Eliminating Sunroof
Does anyone have any experience with eliminating sunroofs? I.E. skin replacement on the roof? Does it leak. I appreciate the help but I am just unsure as if it will work properly?
Old Nov 11, 2010 | 09:22 AM
Sumslapper's Avatar
Year 3030
Default Re: Eliminating Sunroof
Pretty involved task. Why do you want to eliminate it? If you pull the weather stripping on the roof off, you will see seam welds. You have to drill those out and remove your windshield.
Old Nov 11, 2010 | 10:15 AM
Aqualite_Solid's Avatar
Get a CF sunroof plug. Lil expensive but the best way I've seen it donn
Old Nov 11, 2010 | 10:34 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
My guess is OP's sunroof either doesn't work anymore, is broken (glass), and/or for weight reduction, or some combination of those. The sunroof is a pretty heavy component at the very top of the car, which is the worst place for weight to be if you're concerned about curb weight for track reasons.
Old Nov 13, 2010 | 12:09 PM
Lazyfong's Avatar
Anybody know the weight of the sunroof + metal roof skin?
Would like to figure how much weight saving is there from switching to cf.
Old Nov 13, 2010 | 08:01 PM
i read in super street when they did their go green dc that it was abput 50-60 pounds i think could be wrong.
Old Nov 14, 2010 | 04:09 AM
Robinjo's Avatar
I would just get the carbon fiber plug as stated earlier. I guess you could weld in a metal plug, but the CF one looks pretty easy, and I like the CF look.
Old Nov 14, 2010 | 05:31 AM
yeaitsahonda's Avatar
I have been looking into this aswell. I think I have decided on the CF plug or just riveting a piece of sheet metal in to fill the hole. The roof skin just looks more involved/expensive than I would like it to be.
Old Nov 14, 2010 | 05:52 PM
a97b18b's Avatar
couldn't someone just weld in some metal to fill the hole? it would look better than having rivets
Old Nov 14, 2010 | 05:57 PM
pedroa8163's Avatar
do you know the name of the company that makes the cf delete?
Old Nov 14, 2010 | 06:31 PM
pedroa8163's Avatar
the sunroof weights 35lbs, and lighterfaster.com makes the delete that Modified used in their DC2 project.
Old Nov 14, 2010 | 06:42 PM
pedroa8163's Avatar
you'll prob need a non-suroof healiner to go with this the delete, so that the bare metal and cf dosen't show in the inside.
Old Nov 14, 2010 | 08:05 PM
I would like to see the cf inside. Could he jus keep the sunroof slide in the headliner
Old Nov 14, 2010 | 08:09 PM
pedroa8163's Avatar
the delete requires the whole set up to be removed, including the sunroof slider.
Old Nov 14, 2010 | 10:43 PM
user 8508202243's Avatar
that's gona take a lot of body work to delete the moonroof, is this for weight reduction or for another reason?
Old Nov 15, 2010 | 06:24 AM
Community Builder
uh no. That's the whole point of the CF "plug" or insert - to be able to remove the sunroof assembly WITHOUT having to do a bunch of bodywork.
But yeah it would look like complete butt-hole without the non-sunroof headliner, seeing as how the exterior glass piece/hole is larger than the hole in the sunroof headliner.
And yes normally it's for weight reduction, but some ricers will do it for looks, too.
Old Nov 15, 2010 | 06:58 AM
1.8EG-T's Avatar
It is for weight reduction. Thanks for the options and feedback.
GreenTeaLS
Apr 13, 2005 10:27 AM
:jdmshmaydm:
Dec 11, 2002 06:34 AM
Apocalypse
Nov 8, 2002 04:45 AM
