Lighting Diagram/Help Please.
My car was recently rear ended by another vehicle and since then my tail lights and front corner lights do not operate. The blinkers in the front and rear work, all the brake lights work, headlights/high beams work, but the front amber running lights and tail lights do not work. Basically nothing works when you turn the light **** to the first lighting position. It cannot be a fuse because I checked them and they're all OK.
I'm basically looking for a wiring diagram for the lighting or hopefully somebody will know just what the problem is. I heard there is a ground in the trunk, the one that I found looks fine and is intact. I'm thinking a wire got pinched or broken.. Thanks HT.
was going to say sounds like pinched or damaged wire somewhere look over taillight harnesses again. start from the bulb and go from there. take out the taillights and make sure wiring is tucked away and undamaged
mtvcop
12
Aug 31, 2021 08:58 AM
