welders/fabricators in CT
Old Nov 10, 2010 | 08:47 PM
adam00's Avatar
Default welders/fabricators in CT
this might be in the wrong section but i figured id give it a shot and i already looked at the directory. I'm looking for someone in CT that could make me a downpipe and weld some interccoler piping for my car.
Old Nov 11, 2010 | 05:09 AM
downest's Avatar
Default Re: welders/fabricators in CT
I'm over in RI near URI, kind of a drive but if you can't find someone closer we can help you out.
Old Nov 11, 2010 | 05:58 AM
nemisish20's Avatar
Wheres my titleeeee!
Go on CTVTEC and look for CoreyR
Old Nov 11, 2010 | 06:01 AM
adam00's Avatar
Ive been looking for coreyR i cant get ahold of him
Old Nov 11, 2010 | 06:02 AM
nemisish20's Avatar
I will get you his number.
Old Nov 11, 2010 | 08:02 AM
doug118's Avatar
666fabrications or downest
Old Nov 11, 2010 | 08:58 AM
nemisish20's Avatar
I dont think 666 is still going.
try TheShopCT
Old Nov 11, 2010 | 09:05 AM
TheWickedOne's Avatar
John @ Performance & Styling in Manchester,CT. 8606470710
Old Nov 11, 2010 | 09:50 AM
90Rexx's Avatar
Precisionfabrication@live.com
a little bit further of a drive for you... but they specialize in Honda and honda race cars... they do unparalleled fabrication work! worth the drive
Old Nov 11, 2010 | 06:27 PM
hondalover91crx's Avatar
i live in albany, where in CT are you located, im more than capable of fabricating what you need.
Old Nov 11, 2010 | 06:50 PM
adam00's Avatar
I live in new britian
Old Nov 11, 2010 | 07:09 PM
whats your setup and what are you looking to spend.
Old Nov 11, 2010 | 07:26 PM
SingleJingle4dr's Avatar
Go on to ctvtec and there are good people on there that can help you out with alomost anything. hope this helps
Old Nov 11, 2010 | 07:31 PM
adam00's Avatar
Its a d16 with a front mount turbo manifold i need a 3" v band down pipe two 44mm v band dumptube and my intercooler piping welded up up
Old Nov 11, 2010 | 07:34 PM
im assuming the turbo outlets directly into the intercooler then? so you essentially need a cold pipe and a downpie and dumptubes. do you have material or would that need to be supplied also. id do 300 for the down pipe, 200 for dumptubes and depending on what you need for IC plumbing 200-250$
Old Nov 11, 2010 | 07:51 PM
adam00's Avatar
The turbo sits on top and a little behind the intercooler so a hotside pipe needs to be made
Old Nov 11, 2010 | 07:56 PM
pictures would be the best way to eliminate any communication errors.
Old Nov 12, 2010 | 07:05 AM
GTibunny16v's Avatar
Im located in Norwalk, CT. PM me if you want my contact info.
Old Nov 17, 2010 | 04:09 PM
ultrabaka's Avatar
Sorry to highjack but I need emergency welding on my d16 vband obx manifold or a similar replacement in CT.
Michael Foreman
Meets & Events
Apr 25, 2020 10:37 AM
JDMtek
Oct 18, 2009 04:04 PM
evoix4me
Feb 4, 2007 09:55 AM
Mansier
25
Sep 11, 2002 01:22 PM
