ep3 sunroof
go in your roadside tool kit, there should be a tool that looks like a double L, this is an emergency sunroof tool incase the motor blows or you lose power for some reason and need to close it. there should be a spot under the headliner for you to put the tool into and rotate it, if it opens then you know you have some sort of motor issue, if it doesn't then you obviously have something in the tracks and a bad sunroof cassette. Goodluck
mvp4unc
Apr 17, 2017 08:01 AM
QuickRexSi21
11
Feb 11, 2006 02:15 PM
Captain Flaps
Nov 8, 2005 03:23 PM
