car burns oil at stop
Old Nov 10, 2010 | 12:05 AM
Jdmefsir12's Avatar
Default car burns oil at stop
hey whats up i got a stupid question but i guess its worth me asking...
i have a b20 turbo
when i am driving i dont get any smoke. when i am cruising no smoke in full boost no smoke when i stop at a light for like 5 seconds or so ill get a puff of smoke that is oil then it will stop....
before i got my car tuned a couple days ago i did a oil change 10 40 full synthenic but i put 5 quartz......
so i am thinking that it is just to much oil
but plz let me know wat ur thoughts are thanks
Old Nov 10, 2010 | 07:27 AM
DDTECH's Avatar
Default Re: car burns oil at stop
B series take 4.5 quarts, you need to also compensate for the turbo line as well.. i'd assume its not because you put too much in..
is this on coast down, or just like what? Possible bad stemseals, or something of that nature.. remove your intercooler lines and check for oil, if there isn't any, i'd look @ you needing valvesteam seals..
Old Nov 10, 2010 | 01:31 PM
Jdmefsir12's Avatar
ttt
Old Nov 10, 2010 | 01:42 PM
Jdmefsir12's Avatar
if i am driving then i slow down to a red light i sit at light for like 5 to 10 seconds then i get a puff of smoke then it dont do it anymore... just when i stop
Old Nov 10, 2010 | 06:00 PM
blackcurrantgsr's Avatar
Blowby out the turbo probably from over filling it. Once in a blue moon my car well let out a cloud of blue smoke when I stop at a red light, could have oil return line issues too.
Old Nov 11, 2010 | 04:14 PM
Jdmefsir12's Avatar
coo thanks ill let some oil out and see if oil lines are ok
Old Nov 12, 2010 | 06:52 AM
DeLucia's Avatar
Ummmm if he had bad valve seals it would not lead to the IC piping having oil in it. The oil would pass the seals, into the conbustion chamber, and then out the exhaust. It sounds like possibly the seals in the turbo are going bad slowly, this is what would cause oil to be in the IC pipes
Old Nov 12, 2010 | 01:50 PM
Jdmefsir12's Avatar
ok well i havent checked the charge pipes.. but i will... and ill see wat it is
BigZeke5
Nov 11, 2008 07:23 AM
superslow-oto
Jun 11, 2008 10:57 AM
Terrance
20
Jan 6, 2006 10:42 PM
chickenandpickles
16
Sep 11, 2005 01:29 PM
sxecustoms
Nov 9, 2003 06:22 PM
