switching to manual rack subframe question
Old Nov 9, 2010 | 06:02 PM
cincyb20ek's Avatar
Icon3 switching to manual rack subframe question
I am switching my 98 honda civic DX hatchback to a manual rack. I have looking on here and couldnt figure out why people are switching out sub frames. I have seen post where people ar using the del sol subframe. Any suggestions???
Old Nov 10, 2010 | 11:32 AM
93ls10.0's Avatar
Default Re: switching to manual rack subframe question
the eg sub frame had a taller bend(thats what i call it) the the ek frame so u get a lil more room. i usually only see it in the k swaped ek other than that it is pretty point less.
Old Nov 10, 2010 | 05:34 PM
cincyb20ek's Avatar
ok good. cause i didnt know if i was gonna have to change it im my EK hatch when i go to manual rack
Old Nov 10, 2010 | 06:15 PM
94EG8's Avatar
Seagull Management
You swap subframes when going to a manual rack because the holes that the bracket bolts to are in a different spot on power and manual subframes, also make sure you get the lower universal joint for the steering column with your manual rack, those are different too.
Old Nov 10, 2010 | 06:42 PM
cincyb20ek's Avatar
which sub frame would i need to get?
Old Nov 11, 2010 | 03:43 AM
94EG8's Avatar
Seagull Management
'96 - '00 Civic with manual steering.
Old Nov 11, 2010 | 11:37 AM
93ls10.0's Avatar
I did the manual rack with the power sub frame just used the brackets from the power rack on the manual one had no problems
Old Nov 11, 2010 | 04:21 PM
cincyb20ek's Avatar
i will try that when i pull the sub frame out to paint the bay
Old Nov 11, 2010 | 05:53 PM
HondaPartsHero's Avatar
Technical Hero
The subframes are the same no need to swap, I just put power steering in my 96 which came with manual, it'll bolt up without any mods
accord91guy
May 5, 2011 08:33 AM
shortbuss90
Apr 10, 2010 10:25 AM
jord18
10
Feb 7, 2008 10:01 AM
o2flow.net
32
May 16, 2006 08:10 AM
