94-97 abs removal question?
Old Nov 9, 2010 | 05:57 PM
dustinbs144's Avatar
Default 94-97 abs removal question?
i am planning on getting rid of my abs system on my 94 gsr. i read the how to on team integra. i understand that i need a 40/40 prop valve and new front brake lines off a 94 rs. my question is will my master clynder and booster work? is there a differnce between non abs and abs? i heard some people say that it will and some say it wont. can anybody clear this up? thanks
Old Nov 10, 2010 | 10:00 AM
lsturbo33's Avatar
Default Re: 94-97 abs removal question?
Yes you can make it work. Yes there is a difference.
Abs - 1" master cylinder and bigger brake booster
rs - 15/16" master cylinder and brake booster is smaller than the abs booster
To make it work you will need to make 2 custom lines from the master cylinder to the prop valve. If you decide to use the brake booster and master cylinder off of the rs then the rs lines will fit. The abs and non-abs master and booster are not interchangeable. Do not use the abs master cylinder on a non abs booster and vise versa.
Old Nov 10, 2010 | 10:17 AM
hbcrazy88's Avatar
you only need to modify one line if you keep you abs BB and MC. doing that you will need to bend it a little... you can do custom or i just bought oem and bent it with my hands. one the end of the MC closest to your motor you will need to keep that nut and flare that one onto your new pipe for it to work..... does that make since?
http://www.team-integra.net/forum/di...PagePosition=1
you read that one?
Old Nov 10, 2010 | 05:27 PM
you read that one?
yea thanks for clearing that up. thats the one i read. is there a tool to bend brake lines and not kink them? what degree flair tool do i need?
juba_x
Jan 21, 2011 09:51 PM
BCDS
Dec 10, 2008 04:04 PM
Another Drew
Jul 4, 2005 06:35 PM
zCivic
May 4, 2004 05:49 PM
