fuel pump fuse(wire burnout)
Old Nov 9, 2010 | 05:15 PM
dirrtybirdy's Avatar
Default fuel pump fuse(wire burnout)
Hey guys my car isnt priming when on accessory. I changed the fuel pump and its still not starting. I then tested the fuse box and its not getting any juice. How do I go about fixing this problem?
I heard I would have to rewire the connection..but i dont even no where to start with something like this. help!
Old Nov 10, 2010 | 06:52 AM
Default Re: fuel pump fuse(wire burnout)
can anyone help? i searched and didnt find anything relating to this issue. thanks
Old Nov 10, 2010 | 07:36 AM
godslayer's Avatar
Get a service manual and look at the wire/power schematics. Where did you check for power? Did you check the correct side of the fuse? I think you know you need to get power to the fuel pump before the fuel pump can work. Using the schematics you can trace back the wires/relays and find out where the power is disappearing....
See above. If you're not good with the electrical systems then find someone who is or take it in for professional help. There's a reason electrical problems are so expensive to fix/repair....because it takes a lot of understanding and a lot of time to diagnose.
Old Nov 10, 2010 | 08:25 AM
Kronn 98SH's Avatar
Ummmm....what freakin car do you have?
Old Nov 10, 2010 | 09:11 AM
I have a 98 prelude. Sorry.
I used a tester light. i checked bother fuel pump fuse slots. Both did not light up. I checked another fuse slot and it did light up. Is there a site online where I can find the service manual?
Old Nov 10, 2010 | 11:48 AM
Kronn 98SH's Avatar
Go to www.spoonertuner.com/manuals.
Get the regular Service Manual as well as the Electrical Troubleshooting Manual. Notice the name next to each.
Ri5e
Jun 4, 2024 08:52 AM
Ginpaul
Honda Civic (2001 - 2005)
Apr 26, 2018 06:02 AM
fordboy15
12
Jun 7, 2013 02:56 PM
J-MANNN
Jun 21, 2011 09:39 PM
hitman602
10
Jul 20, 2005 02:42 AM
