Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
need help with an electrical issue.
Old Nov 9, 2010 | 03:31 PM
jomondo44's Avatar
Default need help with an electrical issue.
left front turn signal blinking fast and the bulb is good. i can jumper the ground to the bulb to the chassis and it will light up but i still have a fast blink.
Is this a blinker module problem or a wiring issue?
Anyone have a wiring schematic for that front left circuit?
Thanks in advance
Old Nov 10, 2010 | 11:11 AM
bee guz's Avatar
Default Re: need help with an electrical issue.
Is the rear bulb flashing fast also? if you have a fast flash it is usually a bad ground or a cooked flasher.
I would run another ground first, then switch the flasher.
if the 4 way flasher and the turn signal flasher have the same type plug on them, switch them.
ErronEass
Oct 28, 2018 10:00 AM
tk978
Jun 17, 2010 06:33 PM
ed2
Jun 8, 2010 11:09 PM
amit_b82
10
Mar 2, 2008 08:39 PM
ogawa_jiei
Sep 23, 2006 06:10 PM
