KS 1998 LSV-Turbo Integra Frost White
Built this with all intentions of going to the track with it and laying down some good times. Sadly since the car was built last winter, that hasnt happend. Its just been a great daily drive for me haha! So yes i drive this thing just about everyday of the week. Runs like a champ. Taken her out to Saint Louis a few times and have gotten 32mpg on the highway driving from kansas city. Cant Really ask for much more then that out of fully built honda!The only thing the car dosnt have is a/c. Power steering and cruise control and everything else is all there! This is a clean clean car, no honda rust any where on the body! 2 small dings on the whole car that i can find. No clear coat fade, paint shines great! Interior is fresh and free of any tears or wear or stains. Clean Fast and Fun cant beat it! Car was tuned by revline motorsports of kansas city by chuong (Dester223, honda tech moderator on here) I'm looking to either sell it straight up or i might even take a trade plus some cash FOR THE RIGHT CAR. What i'm really looking for is a 96-00 honda civic ex or si coupe, 5spd. Clean, Mostly stock, B or D series motor in the ex is fine. A motor swap is ok if it is done right and it still retains a/c power steering ect. Not looking for another project car. Might even consider a stock integra 94 or newer. Just a more simple clean daily. I am a little OCD on up keep with the car, i change the oil every 1500 miles with full synthetic oil and change the filter as well. Waxed every 2 weeks and always hand washed and well taken care for. One of the cleaner ones around you are going to find! Car comes with a clean kansas title! I am located in the kansas city metro area, i am out in Saint Louis every 2 weeks or so visiting my GF at college so if you want to meet up i will be more then happy to bring the car out with me so you can take a look at it. Text or call for any questions you may have!
Price: looking to some where between $7,500 and $10,500-Cash Talks
make me legit offer and we can work somethting out
913-269-8365-Elliott
The Goods:
Year: 1998
Color: Frost White/Charcoal Gray Interior
Miles on Car: 137,xxx
Miles on Motor: 13,xxx
Bottom End:
b18a1 block
eagle sleeves
eagle rods
CP 9:1 pistons
Arp Rod bolts
ACL bearings
GSR oil pump
Cometic head gasket
Golden eagle oil sandwhich
Head:
p72 (GSR Head)
New kids 2.5 full race port and polish from noland cylinder head of kansas city
3 angle valve job
Victor x Intake manifold
68mm professional products throttle body
880cc precision injectors (with resistor box)
Walbro 255 fuel pump
supertech springs and retainers
Stock GSR cams and cam gears
MSD spark plug wires
NGK spark plugs (9's)
Arp head studs
Tapped valve cover with catch can
Turbo:
borgwarner s362 extended tip turbo
4 inch stainless steel air filter
3 inch down pipe with vband
3 inch exhaust
magnaflow resonator
Vibrant muffler (flat black)
vibrant intercooler
2.5 inch intercooler pipeing/vibrant couplers and t bolt clamps
Greddy type rs blow off valve
Arizona Forced induction ram horn manifold with 44mm v band waste gate
44mm tial waste gate
Turbo smart boost controller
This set up was good for 410whp on 15psi with spinning the dyno up top, Will have graph posted up shortley
Brains:
Hondata s300
honda 4 bar map sensor
AEM wide band
Autometer boost gauge
Suspension:
Full pic Coilovers 8k front/6k rear
pic front camber kit
GSR rear sway bar
Transmission:
LS transmission
Gear speed gears and synchros 1st-5th
OBX LSD (shimmed properly)
Exedy Pressure plate
ACT 6 puck unsprung disc(Just replaced within the past month, was on a 4 puck before)
Cooling System:
Mishimoto half size Dual Core radiator
OEM EG fan with shroud
Wheels/Tires Modifications:
Brakes:
stock rotors front
drilled and slotted rear rotors
Hawk HP pads
Drag dr-23 wheels in kumho ecsta ast tires 205/50/15
Interior/Exterior Modifications:
6K HID kit
20% tint
Pics: all taken within the last month
http://s198.photobucket.com/albums/a...02k10/?start=0
http://s198.photobucket.com/albums/a...2k10/?start=20
The Goods:
Year: 1998
Bottom End:
b18a1 block
eagle sleeves
eagle rods
CP 9:1 pistons
Arp Rod bolts
ACL bearings
GSR oil pump
Cometic head gasket
Head:
p72 (GSR Head)
3 angle valve job
Arp head studs
Turbo:
3 inch exhaust
magnaflow resonator
vibrant intercooler
Brains:
Hondata s300
AEM wide band
Suspension:
GSR rear sway bar
Transmission:
LS transmission
Cooling System:
Brakes:
stock rotors front
Hawk HP pads
6K HID kit
20% tint
Send it to my email. Ill try to upload it for you. moua6388@hotmail.com
nfn15037
Aug 9, 2007 10:22 AM
nfn15037
Nov 23, 2006 06:33 AM
nfn15037
Oct 13, 2006 07:33 AM
i wish someone could upload them for damnit!
