Cooling fan not working (90 crx b16a)
Old Nov 8, 2010 | 06:19 PM
allmotorrex's Avatar
Default Cooling fan not working (90 crx b16a)
what are some of the things to look for? I have no idea why is not coming on...
Old Nov 8, 2010 | 06:51 PM
D16SiHatch's Avatar
Default Re: Cooling fan not working (90 crx b16a)
check to see if the fan comes on when wired directly to battery. if it doesn't, replace fan. if it does, check the coolant fan switch. it is either on the back of the block or on the thermostat housing. jump the wires at the connector. if the fan comes on, replace the switch. if it doesn't come on, check all wiring and coolant fan relay.
Old Nov 8, 2010 | 06:56 PM
JeffBro's Avatar
Usually its the wiring. I have never actually seen a honda fan fail. Since the car is swapped I would check the cooling fan temp switch. If it is a b16a gen 1 then it should be on the back of the block. If its a later model b16ax it will be on the t-stat housing. Check that first. Easy way to test the fan is to jump the relay from the battery power.
Old Nov 8, 2010 | 07:17 PM
hey! thanks for the quick answers gentlemen! i know its going to be a bit tricky getting to the back of the block, there any easier way to do this other than reaching down in a tight little area? my car is also supercharged, not sure if that would have anything to do with it. Also its an aftermarket fan and radiator. .. also is it as easy as running a few wires from the back fan switch, to the battery to check for power?
Old Nov 9, 2010 | 09:30 AM
not exactly sure do i just run wires from the back of the block to the battery?
Old Nov 9, 2010 | 09:36 AM
mruneek's Avatar
no there are TWO wires connecting to the switch (back of block, round brass plug) unplug the wires and take a small wire and connect the two.. then turn your ignition on and if the fan comes on, its that switch. if the fan doesn't come on then you gat relay or wiring problems.. hope this helps
Old Nov 11, 2010 | 06:04 AM
zeusdavis's Avatar
I had same problem a lot of times the wiring can go bad. try running a positive to one connnnetor and run a ground to the other to test if the fan it bad or not.
Old Nov 11, 2010 | 08:05 AM
HBK's Avatar
HBK
I'm dealing with the same problem right now. I jumped the wires and turned on the ignition and the fan worked. So I replaced the fan switch with one that worked off an engine I just pulled and it still doesn't work!
Could it be the relay even if the fan worked off the jumped wires?
Is it possible the wires have a bad connection on the switch? ie corrosion.
I'm going crazy trying to figure this out. Would a bad thermostat cause this? If a thermostat is bad will your temperature gauge still work?
Old Nov 11, 2010 | 08:29 AM
D16SiHatch's Avatar
Originally Posted by HBK
Could it be the relay even if the fan worked off the jumped wires? no
Is it possible the wires have a bad connection on the switch? ie corrosion. yes
Would a bad thermostat cause this? no If a thermostat is bad will your temperature gauge still work? yes
Drain cooling system and remove thermo sensor.
Connect ohmmeter between sensor terminals.
Heat thermo sensor in suitable solution while observing ohmmeter.
Meter should indicate continuity when temperature reaches 190-203°F.
Allow sensor to cool while observing meter. Meter should indicate no continuity as temperature drops below approximately 182-188°F.
If sensor fails to operate as outlined, sensor is defective.
Old Nov 11, 2010 | 09:05 AM
mruneek's Avatar
^^^ agreed
uncleauzzie
Apr 29, 2012 06:19 AM
crxnatic
Apr 4, 2009 05:43 PM
Black Paper Diary
May 19, 2006 03:16 PM
ViXoN Hatch94
Feb 4, 2006 07:53 PM
turbo*s2k
Oct 27, 2003 06:33 PM
