Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
What should the vacuum measure at idle?
Old Nov 8, 2010 | 12:04 PM
creator1322's Avatar
Default What should the vacuum measure at idle?
03 Accord V6 Auto - 170,000 miles
I have the Haynes manual, but I can't seem to find the vacuum reading for when the engine is idle.
Do you know what it should be?
I'm having some pinging issues I need resolved.
Possible problems it says are EGR, Spark Plugs (changed 50,000 ago), Vacuum leak and Fuel Injection System.
Thank you!
Old Nov 8, 2010 | 02:48 PM
LPED's Avatar
Default Re: What should the vacuum measure at idle?
Thank you!
I don't know values for 3.0 V6 but in general a gauge reading of steady needle of 17-21inch is general good reading .
Smaller engines tend to go toward lower end and bigger V8 tend to be in upper .
If your pinging is a part throttle type that happens when opening throttle a bit i would look to clogged EGR valve .
Old Nov 8, 2010 | 06:19 PM
Yes, it seems to be only when partially opening the throttle especially going up a hill at lower speeds where i can actually hear it.
I'll report back after cleaning EGR.
Thank you!
superdave1992
Mar 16, 2016 05:35 AM
mrb455
Dec 4, 2012 05:12 AM
snider
Feb 1, 2012 02:58 PM
rcjordan5749
Jul 16, 2007 11:37 AM
trans_ponder
Mar 30, 2007 06:14 AM
