Suspension & Brakes Theory, alignment, spring rates....
ITR brake setup and rear disc brake conv.
Old Nov 8, 2010 | 11:43 AM
aaroniverson7's Avatar
Default ITR brake setup and rear disc brake conv.
Heyy guys,
I've always wanted to go for a larger brake setup for my 97 EK in the front and do a disc brake conversion for the rear.
I saw a couple of people selling them used and I was wondering if I was to buy them, what do I have to look for when buying used calipers and rotors?
Any inputs would help.
Thanks!
Old Nov 9, 2010 | 08:01 PM
Charlie Moua's Avatar
Default Re: ITR brake setup and rear disc brake conv.
search under creator name "Charlie Moua"
Old Nov 11, 2010 | 06:40 AM
roastbeefrichie's Avatar
Originally Posted by aaroniverson7
Heyy guys,
in order to upgrade to ITR front calipers, you'll need to determine the size of your front knuckles.
if you have 96-00 EX knuckles (or 94-00 integra or 99-00 si), you are using "integra"-sized front calipers, which use a 10.3" front rotor.
if they are NOT 96-00 civic EX knuckles, then you have DX knuckles, which use a smaller caliper & a 9.5" front rotor
Old Nov 11, 2010 | 06:41 AM
Heyy guys,
Thanks!
if you're interested in the ITR caliper upgrade, you'll need to source the calipers first.
the ITR caliper is stamped 17CL15VN
the 17CL15VN is one of the biggest single piston calipers honda produces.
you can easily identify this caliper from the stamp.
this caliper can also be found on:
97-01 ITR,
97-99 CL V6,
91-95 legend,
96-98 rl,
95-98 tl,
92-94 vigor,
95-02 accord v6,
91-97 accord wagon,
97-01 crv,
95-01 odyssey,
92-96 prelude vtec
& 97-01 prelude
Old Nov 11, 2010 | 06:42 AM
once you obtain the calipers, you'll need to seperate the caliper bracket.
the bracket is stamped either 23T, 25T or 28T.
the bracket will need to be milled 2-3mm (or 1/8").
* (the machined brackets will also accept NSX & 94-95 legend 2-pot front calipers)
Old Nov 11, 2010 | 06:43 AM
Originally Posted by BrakeExpert,
Old Nov 11, 2010 | 06:44 AM
Orginally posted by BrakeExpert,
Old Nov 11, 2010 | 06:49 AM
96-00 EX,
99-00 civic Si,
or 94-00 integra knuckles:
ITR calipers w/ 11" front rotor:
http://htarchive.org/showthread.php?t=2765190
DX knuckles:
ITR calipers w/ 10.3" front rotor:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-brake-upgrade-integra-front-brakes-dx-knuckles-1484555/
*you'll need to consider getting a larger MC on DX knuckles w/ ITR calipers
Old Nov 11, 2010 | 06:58 AM
the rear disc conversion is very straightforward...once you acquire the rear disc conversion, everything bolts up
any rear disc will work, all the makes listed below use the same trailing arm, rear caliper (stamped 7CLP13S) and 9.4" rear rotor
90-93 integra DA
CRX Si/ EF civic Si
92-95 civic Si
94-01 integra (except ITR)
del sol Si
del sol VTEC
99-00 civic Si
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-complete-rear-disc-brake-conversion-how-w-parts-pictures-56k-haha-641639/
Old Nov 11, 2010 | 07:20 AM
Trey's Avatar
25 Year Member
....or you can get the scarebird kit and use your existing rear trailing arms. I'd also recommend the EP3 rear disc upgrade with RSX calipers.
Old Feb 2, 2012 | 03:43 PM
diablo2184's Avatar
sorry to revive this but if I got 98 Accord V6 rear calipers for an 95 Integra, do I use the brackets that it comes it or do I need to source new brackets?
Chefskinny
Suspension & Brakes
May 10, 2015 07:52 PM
civicguru
Honda Civic (2006 - 2015)
Nov 6, 2008 04:53 AM
stiffinEK
Mar 30, 2008 08:43 PM
95LSDOHC
Dec 1, 2004 11:32 AM
Ashnice
Jun 30, 2004 02:59 PM
