Wheel balance or warped rotor?
First of all, yesterday, I had tires mounted and balanced and I got an alignment.
On long stops, the pedal starts to shake (not ABS) and then the steering wheel too sometimes... which one is it? Or is there another possibility? Thanks.
That logic makes sense. Thanks for the input guys, I'll have to get it checked out.
My guess is that when I wasn't paying attention, they torqued the bolts down with an air tool.
I hate it when the just drive them on, and then use a torque wrench.
Like what, they'd finnd a loose one?
[Modified by Zygspeed, 6:00 PM 9/21/2002]
Torquing it down to the exact lbs doesn't make a huge difference or probably even one to notice. As long as everything IS tight. Probably rotors or something with your calipers..
[Modified by Type Goch, 3:19 PM 9/21/2002]
If you want to check for wheel imbalance, go on the highway and travel in excess of 70 MPH.
Wheel imbalance is most notice-able at high speeds.
As far as going in excess of 70, I can tell you that I've already done that and there isn't any problem. Guess it's the rotor.
Thanks guys, keep it coming.
