B-series ef not starting
K..so swapped in a first gen obd-0 b16 in my ef, tried starting it and its a no go.
-previous d-series ran perfect
-mpfi done
-brand new dizzy
-reused spark plugs and wires
-reused obd0 injectors with resistor box
-new obd0-obd1 conv. harness
-obd1 p72
-vtec not hooked up yet
Weird thing is while i was checking for spark the engine started... And if i tried putting the plug and wire in the cyl it would die out...
Diagnosed:
-different dizzy
-chked for spark
-set motor to tdc, took cap off dizzy, rotor is facing bottom left
-sparkplug timing order
34
12
-injectors work fine
- fpr gauge reads 40psi
Any suggestions!!!!????
-mpfi done
-brand new dizzy
-obd1 p72
Diagnosed:
-different dizzy
-chked for spark
34
12
LMAOL...OBD0-OBD1 jumper.....hahahaha stick with all obd0...ur ecu is >obd1<...distributor can't be 0 with that obd1 ecu and resister box is only for obd0 you need the obd 0 ecu...i also got one...lol if you want to buy ask...but like i said change that ecu to 0
dizzy is fine..its a t44u (obd1)
I set everything to tdc and the motor was never takin apart either...it starts on 3cyl but not with all sparkplugs/wires in. I've checked all the timing, plugs and wires are good..im hookin up my oil pressure gauge tmo to see if im getting any pressure.
there should be a two wire plug on the passenger side of the car under the dash in a green rubber cover thing. when you find it turn the car on try to start it then leave the key on run. jumper the two wires with a paper clip or something. the check engine light will flash.
ps just for diag take move the map to the fuel pressure regulator vac port on the manifold try to start it like that
k..tried that, and also tried starting it with oil cap off(thinking maybe too much crankcase press.)..so im gonna try 2 more things..compression test an reset timing and if that doesnt wrk im gonna blow the car up..ne other suggestions?
kantspell- waiting on a friends ecu..under the impression its just my ecu thats fukt
tagperformance-checked timing(first post)..but I cant use the timing light unless the car is running right..
Cimburke23
33
Sep 1, 2006 05:59 PM
