mystery marvel oil?
Old Sep 21, 2002 | 10:22 AM
N~FaMouSKhMerBoi's Avatar
Default mystery marvel oil?
hey i sucked some water up the other day...and somone told me to use some of this product....how do i use it?..just wanna ask someone who had has experienced this..thanks! i have a 98 integra ls..
Old Sep 21, 2002 | 03:03 PM
Mr. Choi's Avatar
New User
Default Re: mystery marvel oil? (N~FaMouSKhMerBoi)
how do you want to use it? i once put that thing in with gas so it'll lubercate the top side of the pistion. man did it rob major power for that tank of gas. there are directions on the bottle too, jus follow their directions. i also use this on my rc car engine. i guess it works.
Old Sep 21, 2002 | 09:56 PM
baonest1's Avatar
Default Re: mystery marvel oil? (Chois i-VTEC)
that is some good stuff....
Old Sep 21, 2002 | 11:05 PM
TREVER's Avatar
Default Re: mystery marvel oil? (baonest)
It's Marvel mystery oil. I use it in my air tools.
Iv'e had heard oldtimers say they use it in oil/gas, I don't think it helps much nowadays.
Old Sep 22, 2002 | 10:21 AM
TimoneX's Avatar
New User
Default Re: mystery marvel oil? (TREVER)
I got a can of that stuff around here. I too use it for air tools. Don't think I'd put it in my engine.
Old Sep 23, 2002 | 12:58 AM
aeolus's Avatar
Ive seen people remove the spark plugs of cars that have been sitting for a long time and pour a little into each cylinder to help free up the rings incase they could be stuck.An old hot rod trick.It wont hurt to pour some in the cylinders since the rings may be rusted together against the cylinders.If that doesnt help,then you may need to do a rebuild anyway.good luck!
Old Sep 23, 2002 | 05:18 AM
TimoneX's Avatar
New User
Default Re: mystery marvel oil? (aeolus)
That's done if the car is sitting for months without being turned over. He's worried he might have hydro-locked. Here the damage would be caused in a split second, not from oxidation over time. When that piston comes up and tries to compress a combustion chamber full of water and can't...something will give, and it won't be the water.
Old Sep 23, 2002 | 09:53 AM
RallySportCivic's Avatar
Default Re: mystery marvel oil? (TimoneX)
if you sucked up some water, I hear you should take you spark plugs out turn the key, I remeber my dad did this once in an old jeep cj 4x4 when I was a kid, saved the motor. It will pump all the water out. I think you still have to replace spark plugs with new one because the water can foul them? I am not sure if this will work, but maybe
boostedfe3
Jun 22, 2005 04:57 AM
eddiecut
Mar 25, 2003 07:53 PM
MeanGreenEG9
Jan 15, 2003 05:27 PM
mattL
Nov 13, 2002 11:25 PM
calcnerd
Sep 30, 2002 11:25 AM
