1998 3.0cl will not run
Old Nov 7, 2010 | 09:06 PM
hondapowerrulz's Avatar
Default 1998 3.0cl will not run
does anyone know how to reset the ecu/immobilzer ? car will not start no fuel or fire but turns over .. no flashing key light at all tried to hook a scan tool up and there is no connection to be made??locked out because of the immoblizer maybe?? .. HELP!!!
Old Nov 8, 2010 | 07:09 AM
nus_dogg's Avatar
Default Re: 1998 3.0cl will not run
Time for a diffferent ECU?
Old Nov 8, 2010 | 07:53 AM
would there have anything to do with the key switch? because, theres a recall in the switch .. any info would be a godsend.. i have a newborn son and no car !!but the nearest acura dealer is 88 miles from here
Old Nov 8, 2010 | 08:22 AM
Simactive's Avatar
By key switch are you talking about the Ignition Switch, the recall honda did because they wouldn't start unless you held the key near the start position? If so your car would start for a second and then shut back off. Immobilizer wouldn't lock you out of the ECU, shouldn't anyways.
Does the main relay click on and off? Can you hear the fuel pump prime it self before starting, it will sound like a mechanical wine.
pablo808
30
Nov 30, 2017 02:53 AM
eagleclawracing
Feb 19, 2012 04:39 PM
st_rage
Nov 29, 2008 01:38 PM
slow hatch
Apr 19, 2004 10:00 AM
oMek
Oct 29, 2003 04:16 PM
