Loses power at 4k as if on a switch.
Old Nov 7, 2010 | 08:27 PM
Rigginit's Avatar
Default Loses power at 4k as if on a switch.
May have something to do with another problem Im having:
https://honda-tech.com/forums/showth...7#post43959287
But since it seemed to pop up later than that problem; Here goes:
94 civic Si B18A1. Pretty much stock aside from some bolt ons (ran good with these for 2 years+)
Test drove it and pulled good until 3800-4k every gear it seemed except first (gear may be too low to notice) in a second gear pull it literally put me forward in the seat some as to how much power it let off of. It seems as if 30HP just disappears on a switch as if opposite of Vtec.
It doesn't bog, miss, sputter or anything noticeable and it isn't gradual. It's something i haven't encoutered before.
Any info needed Ill be glad to supply.
Old Nov 7, 2010 | 08:34 PM
2k.civic.si's Avatar
Default Re: Loses power at 4k as if on a switch.
will it go past 3,800-4k?
Old Nov 7, 2010 | 08:38 PM
Rigginit's Avatar
Yea it does no problem. Aside from the linked problem, it has no other problems than this one once warmed up.
Old Nov 7, 2010 | 08:47 PM
and what ecu? is the ecu chiped?
Old Nov 7, 2010 | 08:49 PM
Rigginit's Avatar
Chipped P75 but with only a stock map burned on it. Haven't messed with any of this in years as its ran fine with it.
trf1driver
Jul 6, 2012 08:47 AM
Pumpking.
Jun 21, 2010 09:09 AM
93FastLs
May 9, 2007 05:45 AM
chronoshift
Aug 15, 2002 06:51 AM
