GSR Intake manifold swap & Why?
Old Nov 7, 2010 | 06:07 PM
CaliforniaDad's Avatar
No-Traction = Fun
Default GSR Intake manifold swap & Why?
Just wondering why I see people swap out there stock GSR intake manifold, with a single length runner manifold. What are the pros: and cons: of doing this? Is this something I should do when I go FI?
Thanks
Old Nov 9, 2010 | 05:25 PM
joe b's Avatar
Default Re: GSR Intake manifold swap & Why?
Well they say it gives you more topend power . Some people remove the butterfly valves . I for one just left mine on . The stocker is very under estimated as i just ran a 10.6 @ 137 with mine in a 2650lb gsr . I would spend money elsewhere first .
Old Nov 9, 2010 | 08:13 PM
No-Traction = Fun
really? man roger that one!! so is that what i'm hearing close to red-line, the butterfly's opening.
Old Nov 10, 2010 | 06:20 AM
joe b's Avatar
The butterflys open @ 5700 rpm so i dont know what you are hearing at or near redline .
Old Nov 10, 2010 | 07:00 AM
No-Traction = Fun
Yeah sorry, thats what I meant.
Old Nov 10, 2010 | 07:19 AM
2kdb8's Avatar
upgrading to a aftermarket single runner intake will give you better top end power if tuned. but the con is you will lose some low end torque that was provided by the stock's 1st stage longer skinnier runner. so a dual stage stock intake would be more ideal for daily driving but a single stage intake would be better for racing when you always stay high up in the rpms and dont really use the 1st stage of the intake. i would spend money else where like already mentioned and keep the stock mani until you really need to upgrade it. i still have my stock intake mani and love it when the butterflys open!
Old Nov 10, 2010 | 01:24 PM
Westrock2000's Avatar
Also, people probably like seeing the runners/plenum/throttlebody up in a viewable position rather then curled under.
I know most people wont admit that, but who are we kidding here
Old Nov 10, 2010 | 09:50 PM
IN VTEC's Avatar
We did as much as 450whp on a 81.5mm motor with a stock GS-R manifold and cams.
We learned that the low runners max out at around 270whp when the first tuner clamped the short runners closed thinking it was open.
I recommend using it until you have some data that says the single runner manifold is much more efficient or faster than the stock manifold. We had intended to move up to a JG manifold to see what it would do but we tanked the motor before we could do that.
Old Nov 10, 2010 | 10:10 PM
No-Traction = Fun
Okay great info, as I only plan on 300-320 whp for my Daily.
Thanks!!
Old Nov 11, 2010 | 11:07 AM
AlexDphoto's Avatar
switching up to a skunk 2 intake manifolds help make power up top due to the runners, and eliminate the butterfly valves that the stock gsr manifolds have, so instead of a 2 stage vtec, its a single stage when it crosses over all at once. nothing everyone else didnt say up there though ^^^ lol
Old Nov 11, 2010 | 11:16 AM
95skunkedgsr's Avatar
2 stage vtec ????? never heard of that term used.... depending on what size turbo you have i can see where the gsr mani might limit spool of the turbo... or make it spool up later
Old Nov 11, 2010 | 11:17 AM
or make it spool up faster ... wouldnt know till it was tested
Old Nov 11, 2010 | 11:21 AM
AlexDphoto's Avatar
stock gsr manifolds have 2 different stages for vtec
correct me if im wrong, its been a while since i explained this
@ 4400 rpms vtec is activated and the primary butterfly valves open
@ 5500 rpms the gsr manifolds secondary butterfly valves open
These skunk 2 and blox manifolds are sort of like ITR copys in their runner design and in the fact that they eliminate the butterfly valves so vtec is 1 crossover.
However, there is a way to eliminate these butterfly valves in stock gsr intake manifolds as well.
EDIT : My mistake, this article here explains the GSR vtec engagment
Coupled with VTEC, you can see the GS-R engine has three stages of operation.
Stage 1 (0-4400 RPM): Low-lift cam lobe and long intake runners.
Stage 2 (4400-5800 RPM): High-lift cam lobe and long intake runners.
Stage 3 (5800+ RPM): High-lift cam lobe and short intake runners.
This three stage system is how the GS-R is able to keep a flat torque curve. Changing to a single-stage intake manifold such as the Skunk2 would amplify the cam lobe change and you would see a double hump torque curve similar to the Type R.
taken from Team-Integra.net
Old Nov 11, 2010 | 11:22 AM
2kdb8's Avatar
wrong! although the part you got from team-integra is right. vtec has 1 stage, at 4400rpms (gsr) it engages and the higher cam profile is used. the intake manifold has 2 stages, 1st stage 0-5750 rpms uses long skinny runners and the 2nd stage butterflys open and the short fatter runners are used. vtec has no butterfly's.
Old Nov 11, 2010 | 11:41 AM
AlexDphoto's Avatar
I was referring to the gsr manifold not vtec lol i get what you're saying i suppose my wording was goofy
Old Nov 11, 2010 | 12:35 PM
ghostskinner's Avatar
so what if you just leave the butterfly open all the time what then
Old Nov 11, 2010 | 04:51 PM
No-Traction = Fun
Yeah x2 ^^^
Old Nov 11, 2010 | 05:15 PM
joe b's Avatar
You will loose power and torque in the low end .
Old Nov 14, 2010 | 04:57 PM
No-Traction = Fun
Default Mirage power IM
Is this manifold pretty much junk? Would I be better off keeping my stock manifold for boost?
http://cgi.ebay.com/ebaymotors/94-01...item19b5c57941
Old Nov 14, 2010 | 05:14 PM
AlexDphoto's Avatar
your manifold will be fine for boost. If you want to switch up to one and be easy on the wallet look at the blox one. Almost exactly the same as the skunk 2
Old Nov 14, 2010 | 05:53 PM
No-Traction = Fun
Oh okay one of these ..http://cgi.ebay.com/ebaymotors/BLOX-...item2eb124bb7e
Old Nov 14, 2010 | 05:57 PM
AlexDphoto's Avatar
yup, I have a couple friends who are using those on their cars without any problems, unless you dont like "knock off" companies
Old Nov 14, 2010 | 06:43 PM
No-Traction = Fun
Nah.. I dont really care. I would probly peell the sticker off anyways and shoot it with some wrinkle finish black paint.
Oh I found it a little cheaper here + free shipping.
http://www.autopartsdealer.com/blox_...tent=APD443784
Old Nov 15, 2010 | 01:43 PM
Turbo-LS's Avatar
Leave the stock manifold or pick up a blox. The minimal gains down low the stock provides vs a blox top end isnt worth it so if you really want to spend money geta blox, same as skunk2. otherwise stick with stick it will perform with stock configuration and some moderate boost with properly sized equipment
Old Nov 15, 2010 | 02:30 PM
No-Traction = Fun
Oh okay, so I guess I can spend the money somewhere else.
