Suspension & Brakes Theory, alignment, spring rates....
Front Upper Control Arms Installation
Old Nov 7, 2010 | 07:31 AM
giperbolic's Avatar
Default Front Upper Control Arms Installation
I'm trying to install Hardrace front UCAs with sliding ball joint. Repair Manual mentions aligning the marks on the bolts/bushings and UCAs, then torquing the bolts prior to installation of the UCAs on the car, but Hardrace UCAs don't have the marks for aligning them, even if they did, these marks will not be true anymore since I'm lowering the car. My questions is: Why not install the UCA loosely, just tighten the ball joint, then raise the car by the lower control arms until it's off the jack stands and torque those bolts?
Thank you.
Old Nov 7, 2010 | 07:49 AM
Spawne32's Avatar
Default Re: Front Upper Control Arms Installation
ill let you know when i actually get my hardrace UCA's, because i got told nobody knows anything about my order cus apparently the whole place went to the SEMA show. buyhardrace.com seems to be the only place to get these things.
shahriar35
Jun 25, 2016 10:38 AM
HondaCivic2006
Suspension & Brakes
Mar 7, 2009 08:20 AM
iwanttogofast
Jul 19, 2008 09:14 AM
Jape
Nov 13, 2002 04:35 PM
