90 Hatch...Starts quick then Dies. Need opinions
Old Nov 6, 2010 | 01:39 PM
Slippery-Worm's Avatar
Default 90 Hatch...Starts quick then Dies. Need opinions
Hey guys...was cruising last night at about 2k rpms in 5th. I could feel the car lose power in the pedal and it shut off on me. It will fire right up now and as soon as it starts, it will die before it even has a chance to hold an idle. I tried giving it gas to keep the rpms up but it just popped out the exhaust and died. I figure, ok it's got to be fuel. Well the filter is new, the relay is working (clicking on and off) properly, and I can hear the fuel pump humming when I turn the ignition to the III position. Just wanted to know if maybe although the pump is priming, its still possibly dead and can't hold/feed the engine enough pressure when running. BTW it's a stock 90 hatch with DPFI. Any opinions welcome.
Old Nov 6, 2010 | 01:58 PM
hatchet_honda's Avatar
Default Re: 90 Hatch...Starts quick then Dies. Need opinions
check the rotor inside of distributor. could be loose..screw flew out or something, its happened to me. just backfires and dies
Old Nov 6, 2010 | 02:28 PM
Laserjock's Avatar
This is what happened to me. Rotor screw was MIA.
Old Nov 6, 2010 | 03:52 PM
Hmm...I'll check on that tomorrow then. Much cheaper/easier than doing a fuel pump. Any more suggestions welcomed. Thanks guys
Old Nov 6, 2010 | 09:11 PM
sirtef9's Avatar
engine codes?
id say check the coil.
Old Nov 7, 2010 | 04:57 AM
djstevehawken's Avatar
You may have an ignition switch problem. The same thing happened to my 91 STD Hatch 2 years ago. The car would start then die as soon as it started. I replaced the electrical part of the ignition, Part# 35130-SH5-505.
Old Nov 7, 2010 | 07:52 AM
Datunnerkid's Avatar
Check the ignition coil. You might not be getting enough spark.and if that dose not work check the injectors.they could be dirty or bad. My buddy had both these problems at the same time and it took forever to figure out.
Old Nov 7, 2010 | 08:43 AM
well the rotor is nice and tight...hmm, could be the coil or the ignition switch. I'll check on those. Just trying to do all I can before I spend $130 on a pump and drop the tank
Old Nov 7, 2010 | 12:03 PM
Well I checked and the car is getting spark...therefore I know the ignition is working as it should. I have the tank dropped now changing the pump. I'll see what happens...
Old Nov 7, 2010 | 01:44 PM
changing the pump is alot of work. shoulda checked fuel pressure while cranking the car over first before digging into that
Old Nov 7, 2010 | 03:21 PM
It wasn't too bad...Took me maybe 2.5 hours, and the pump in it was original with 360k miles. Now my car has a new pump, but still no fire. Replaced the cap n rotor as well. I'm kinda stumped on this one. I guess all that's left is injectors... I think I might just pull the engine and start over lol
Old Nov 8, 2010 | 12:24 AM
ignition switch...they are cheap. try that. if it fires up then dies as you release the key...yep
aymoushz
Honda CR-V & Element
May 17, 2014 03:31 PM
redef90si
18
Mar 9, 2010 06:48 PM
fin781
Nov 2, 2009 05:30 AM
The_In_Kid
Sep 8, 2002 10:26 PM
xsnrgsr
Apr 29, 2002 08:36 PM
