1999 Integra GSR-T Built
problem was fixed...
clean title
Hot rod black (professionally done) not primer
Power steering still works
all the abs stuff is still intact
No leaks or Burning
Motor setup-
B18C1 block
84.5mm bore
decked
o-ringed
Golden Eagle Mfg. HD sleeves
Eagle big bolt rods
Wiseco Pistons 84.5 mm 8.8:1 comp. ratio
King main bearings
ACL rod and thrust bearings
Line bored
Bored and honed
Balanced rotating assembly
Sized, micro-polished and magnafluxed crank
Chamfered oil hole
GSR oil pump
Moroso Oil pan
All brand new seals throughout
Head
fully ported and polished
milled 0.25
type r dual springs and retainers
type r valves
gsr cams
str cam gears
mugen valve cover
mugen oil cap
Hasport mounts
LSD trans
Fresh honda transmission fluid- (11/08/10
Stage 4 clutchmasters clutch
act flywheel
skunk2 short shifter
type r shift ****
Blox Shift ****
Turbo setup
Aebs Intake Manifold
Blox Vacuum box
Blox boost controller
Blox fuel pressure regulator and gauge
Blox Boost Gauge
Front mount intercooler
Blox Turbo manifold
Emusa T3/T4 turbo NEW
38mm Wastegate 7Lb spring (boosting 9lbs)
Turbo xs bov
3" downpipe
Blox FMU
Walbro 255 Fuel Pump
Stock Injectors
Exterior
Type R lip kit (missing the sideskirts now, but has sideskirts)
3" Thermal R & D catback exhaust (sounds good)
Suspension
Ebay adjustable Coilovers all around
Blox upper control arms
New lower ball joints
Interior
Clean Black interior
Bone stock
Stock radio with code
Black leather Seats (driver seat has rip in it)
Bad:
Fender needs to have dent pulled and has to be painted ( i think i might have dented it when i was leaning over the fender)
needs to get tuned running a street tune on 9lbs right now.
Trades im willing to take are - eg's, crx's, ek's, em1's, ep3, srt4s, 240s. ECLIPSE'S, Talons, WRX's. etc.. please dont offer me a rusted out bucket with a swap, BE REASONABLE with trade offers....PLEASE.... Also this isnt your average boosted integra with the right injectors and right tune you can make around 400hp.....
KEEP Negative COMMENTS TO YOURSELF PLEASE
pics are on this thread because i cant copy and paste pics. also the price went up because i got out of the financial issue i was in.... so i dont really care for the money that much.
http://hondamarketplace.com/showthread.php?t=2851932
clean title
No leaks or Burning
Motor setup-
B18C1 block
84.5mm bore
decked
o-ringed
Eagle big bolt rods
King main bearings
Line bored
Bored and honed
Chamfered oil hole
GSR oil pump
Moroso Oil pan
Head
milled 0.25
type r valves
gsr cams
str cam gears
mugen valve cover
mugen oil cap
Hasport mounts
LSD trans
act flywheel
type r shift ****
Blox Shift ****
Turbo setup
Blox Vacuum box
Blox Boost Gauge
Blox Turbo manifold
Turbo xs bov
3" downpipe
Blox FMU
Stock Injectors
Exterior
Suspension
Interior
Bone stock
Bad:
