D16z6 cel problem
Old Nov 6, 2010 | 06:26 AM
EF_Tovi's Avatar
Default D16z6 cel problem
Well we did a D16z6 swap during the summer and everything was fine, no cels. Then recently I had to unplug some of my wires like the distributor, vtec solenoid, all the ones in that area so I could put a thermostat in. After I finished putting in my thermostat and plugged everything up my car had a cel. Anybody know how to read cel codes on the p28 ecu since there no built in light? I think it's the vtec solenoid but I can't really tell if it's engaging cause it's a sohc.
Any help will be appreciated
Old Nov 6, 2010 | 06:51 AM
wasabivtec's Avatar
Default Re: D16z6 cel problem
Did you use a jumper for the ecu?
Old Nov 6, 2010 | 06:54 AM
EF_Tovi's Avatar
Yea, we used a jumper harness.
Old Nov 6, 2010 | 07:20 AM
wasabivtec's Avatar
there should be 2 extra wires hanging off of it that you needed to hook to a toggle switch. If you didnt do this, for now just tie those leads together and turn the key to on.
Kelvartis
Jul 5, 2014 05:17 AM
NeedaJaDayEj1
32
May 29, 2012 07:28 AM
HiProfile
Jul 23, 2005 08:38 AM
serious
Apr 7, 2003 02:58 AM
