88 trans upgrade disc?
Old Nov 5, 2010 | 08:18 PM
hatchet_honda's Avatar
Default 88 trans upgrade disc?
i got an 88 d series trans that i was told was from a 91. well i didnt think to check and ran into a prob when i go to install the trans. the trans isnt gonna fit the 91 clutch and flywheel i have obviously... ive heard talk of some upgrade disc that act makes? that allows use of the 90-91 pp and flywheel but has 21 splines to fit the 88 input shaft?
Old Nov 5, 2010 | 08:20 PM
BiG ChOr!Zo's Avatar
Default Re: 88 trans upgrade disc?
why not just get a 89-91 flywheel and clutch kit...!!!
Old Nov 5, 2010 | 08:31 PM
already have a 91 clutch kit....and its goin in a d16a6 that im using to make my b swapped dx pass emissions. then im pulling it right back out, dont wanna spend 200 bucks if i dont have to
Old Nov 5, 2010 | 08:35 PM
are you using the proper flywheel...?
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/stock-clutch-fitment-guide-2284956/
Old Nov 5, 2010 | 08:42 PM
https://honda-tech.com/forums/showthread.php?t=2284956
its the stock flywheel that came on the d16a6. so i assume 212mm. im reading that chart and are you saying i can use a disc from an 88 accord??
Old Nov 5, 2010 | 08:45 PM
im not saying what you can or cant use so just go by what the chart says...!!!
Old Nov 5, 2010 | 08:50 PM
hell its worth a try i guess. this engine came with a clutch that was new. like a month old. id only be driving it a few months then pulling it back out so i was gonna reuse the parts. ill have to look up that disc for an accord
Old Nov 5, 2010 | 08:53 PM
30 bucks at autozone. 21 spline count lol
Old Nov 6, 2010 | 08:36 AM
efjones9's Avatar
as long as u have the correct size disc that meets the flywheel and slides on ur tranny u should be cool. cuz i know that the 88 trannys have different size clutches
Old Nov 6, 2010 | 09:06 AM
Tyson's Avatar
you should buy the hybrid kit from clutchcityonline.com made specifically for ppl with 88 trannies and 90+ flywheel.
if you just need the disc, you can get it from them separately too. just contact them. they have great customer service.
Old Nov 6, 2010 | 11:39 AM
i ordered the 88 accord lx-i clutch disc. 30 bucks from autozone.
Old Nov 6, 2010 | 12:02 PM
Tyson's Avatar
just so you know, the accord disc is 8.25" or 210mm.
the disc clutchcityonline sells is 8 3/8" or 212mm. which is the proper size for a 90+ flywheel.
but i think youll be fine being a 1mm less at the edge.
Old Nov 6, 2010 | 12:07 PM
where is that part located on the website...ive looked and see nothing specific
edit.: i found that disc. 88 upgrade disc by act. its like 89 bucks. should that smaller accord disc pose a prob? itll be here tuesday so i guess ill just compare it to what i have and if it looks iffy ill just order the act part
Old Nov 6, 2010 | 12:15 PM
Tyson's Avatar
http://www.clutchcityonline.com//products/08-009F.shtml
fixed link
exedy, not ACT.
like i said, youll be fine. others have used the accord disc too.
Leland
16
Sep 29, 2009 02:05 PM
mario_pic
Dec 31, 2007 11:36 AM
orido 1.6
Jun 6, 2004 12:45 AM
pisetup
15
May 30, 2004 02:08 AM
DC2-JRSC'd
Mar 29, 2004 12:37 PM
