91 CRX Sputters under 3000rpm
1991 CRX DX, 100% stock D15B2, manual tranny.
New distributor (reman), cap, rotor.
No CEL/Code's.
Car ran fine then suddenly started sputtering under high load or bellow 3000rpm. Rev it up past that and it's like all power returns and it runs fine. But bellow 3000rpm it sputters real bad.
Just replaced the distributor (although remans often suck), cap, and rotor. Ran fine again for ten minutes (let it idle and warm up), then at full temp it started running like crap again.
I'm doing fuel filter, plugs, wires tomorrow. Any other ideas?
I've googled it, seen that it could be TPS, EGR (dx have EGR?), maybe 02 sensor (does it have 1 or 2?).
Thanks.
No CEL/Code's.
Thanks.
un plug the 02 then drive it. if no change or worse. plug back in and reset ecu. Unplug the tps and drive no change or worse, reset, unplug map etc.... once you find it the factory base map limp home mode should run better. It is getto but it works for the most part.
try this^^
KaBlookie
Jan 23, 2016 07:01 AM
barney_SI
Nov 30, 2009 05:09 PM
RuffRhyno
Aug 29, 2002 07:00 PM
