Help Hooking up speaker wires to AMP
Old Nov 4, 2010 | 04:28 PM
chrisff521's Avatar
Default Help Hooking up speaker wires to AMP
I need help setting up speakers to a 4 channel amp. All the wires are there already and hooked up to the speakers and the Amp is powering on/off. I just need help establishing a signal from the head unit to the amp to the speakers.
I have a Alpine Vpower Amplifier that has 4 Channels.
I have a Kenwood Stereo that displays protect which Im guessing becuase its not getting the speaker signal.
Heres pics. I dont know what Im doing wrong and where the RCA cables connect to. I tried every possible one and still doesnt work.
Heres what the Amp looks like but with only one fuse. Its a similar model.
http://a248.e.akamai.net/pix.crutchf...MRPF300-L.jpeg
http://a248.e.akamai.net/pix.crutchf...MRPF300-i.jpeg
Old Nov 4, 2010 | 04:42 PM
joeymc13's Avatar
Default Re: Help Hooking up speaker wires to AMP
You need RCA cables to run from the preamp outs of the kenwood to the amp. As far as the amp saying protect, you shouldn't be using any of the white, grey, green, purple wires coming from the back of the kenwood, cap those off so they don't touch metal, then you will prob have to reset the kenwood.
Old Nov 4, 2010 | 04:44 PM
joeymc13's Avatar
You can also use the highlevel input (that black 8 pin plug on the amp, if you've got the plug, but running RCA's would prob be easier...)
Old Nov 4, 2010 | 04:46 PM
chrisff521's Avatar
I can just run one set of RCA cable?
Old Nov 4, 2010 | 04:50 PM
Cobb2819's Avatar
you will lose your fader, but you can run one set and then use y-adapters to split the signal to front and rear
chillerice
Audio / Security / Video
Oct 1, 2012 09:44 AM
Maple50175
Apr 8, 2008 06:15 AM
vidanator
Feb 23, 2006 02:34 PM
lotas
Aug 20, 2004 10:21 AM
dFreezy
Jan 13, 2003 02:13 PM
