The causes the Rev on low RPM on 99 Sh Prelude
Old Nov 4, 2010 | 12:49 PM
kamranm3's Avatar
Default The causes the Rev on low RPM on 99 Sh Prelude
I apologize for the confusion.
The first question was; Sometimes when i accelerate it wont let me rev past the 6800 RPM or even 5K RPM. But normally i can rev up 8K. So what could cause that.
Also when I launch in first gear, it will pop out of the gear around 7-7.5K RPM. What could be wrong? My ATTS light is on, could that be causing the gear pop out??
Thank you guys for any input. Im fairly new to this stuff so please be more specific.
Thank you!
Old Nov 4, 2010 | 02:14 PM
Kronn 98SH's Avatar
Default Re: The causes the Rev on low RPM on 99 Sh Prelude
Ummm....I don't understand the title or Question 1. Try again?
Old Nov 4, 2010 | 02:15 PM
GraphiteMW's Avatar
Not quite understanding the question, your transmission pops out of 1st gear when you hit 6.8k rpms?
Old Nov 4, 2010 | 02:25 PM
Tunerguy1989's Avatar
If i'm understanding your question2 correctly when you accelerate to 6800 rpm your first gear is pop out of gear, I would say change your transmission oil I'd recommend Torco MTF its awesome in honda trannies. If that doesn't work then you probably have and internal problem. I do not understand you first question.
Old Nov 4, 2010 | 07:17 PM
kamranm3's Avatar
bump
Old Nov 4, 2010 | 09:01 PM
Kronn 98SH's Avatar
1. IDK, are you at operating temp when you do this?
2. No, your ATTS light wouldn't cause or even indicate a transmission malfunction.
Old Nov 5, 2010 | 06:43 AM
TurboBB2's Avatar
It's just the tranny.. prob the sleeve things it happens when they get older or have been driven hard on for a long time.. its normal wear and tear. i dont know what would stop you from revving past a certain rpm though.. if its in limp mode i think it wont rev past 3k or atleast thats what mine did.
I had a transmission that was really broken when i first bought my car.. second third and fifth syncros and sleeve things were bad (i really dont know what they are called lol..) I had to hold the shifter in place so it would not pop out of gear, so you could try that... or maybe try babying first since it already has issues and just rip it in second... and i had to match the rpms on the tranny gear so that it would just slip in place haha.. bad clutch too.. it wasnt very fun. =(
Oh, and if you are doing a tranny flush this is the best stuff to use... period.
http://www.summitracing.com/parts/NAL-12345349
Old Nov 5, 2010 | 07:36 AM
1GPlusSH's Avatar
Oil, your motor needs it; it sounds like you don't have it or have low oil pressure.
NathanielH
May 16, 2007 11:49 AM
Jeff99Base
May 21, 2005 11:40 AM
98prelude98
Sep 4, 2004 09:29 PM
acurciv
Mar 5, 2004 09:53 PM
1SlowSi
Feb 25, 2004 05:59 AM
