ECU wiring help
Old Nov 3, 2010 | 09:09 PM
chrysanderson's Avatar
Default ECU wiring help
ok so im doing a mpfi conversion as well as a mini me swap.
does anyone know of a website that explains how to slice the ecu wires together?
Old Nov 3, 2010 | 10:41 PM
efjones9's Avatar
Default Re: ECU wiring help
splice them? or de-pin them
Old Nov 3, 2010 | 10:47 PM
splice them. buddy of mine said to cut my obd0 ecu plugs off an slice on my obd1 plugs so i can run my p28 ecu
Old Nov 4, 2010 | 06:06 AM
stella88's Avatar
the info is on here ya just gotta keeep loookin...here's a link I used to help me double check the wireing VAdriven.com "all ya need to know for a DPFI to MPFI conversion"
Im rather an idiot on the computer...hopefully that will get ya there
Old Nov 4, 2010 | 06:09 AM
crx_si-r's Avatar
buy an obd0 to obd1 ecu jumper harness. if anything messes up later then you can still convert back to obd0.
Old Nov 4, 2010 | 08:12 AM
efjones9's Avatar
yes! but if u dont want to have a jumper u can just de pin all the obd0 wires to the obd1 plugs. back breaking labor tho
Old Nov 4, 2010 | 08:22 AM
crx_si-r's Avatar
This is Only true for some of the pins. Obd0 plugs have bigger pins on 1 connector where as the obd1 ecu uses about 5-8 pins that are big than the rest of the plugs. So the OP will still need to do some splicing/soldering.
I could be wrong on the number of bigger pins, just going off the top of my head.
Old Nov 4, 2010 | 12:38 PM
alright so im jus gunna get the jumper harness then.
thanks guys
meallout
Jan 25, 2009 12:21 PM
I AM WEASEL
Dec 21, 2007 08:10 PM
G2integra217
May 8, 2005 11:39 PM
Bseries
Feb 3, 2003 06:00 PM
