Axle seal?
Old Nov 3, 2010 | 07:01 PM
nicknack25's Avatar
Default Axle seal?
My car is leaking on the tranny side and i have a feeling that it is the axle seal.. but i heard if you can move the axle around like up or down then it could be the differential. I already have some bad bearings in my tranny btw. I dont know if that helps
Old Nov 3, 2010 | 07:54 PM
pimpwagon's Avatar
Default Re: Axle seal?
id say just source a used tranny and swap it. it only takes a few hours.
hatchet_honda's Avatar
welll the seal is what prevents the oil from leaking. sooo i assume its the cause. buuut if the diff bearings are worn and the axle moves a bit then that could cause the seal to wear out faster
Old Nov 3, 2010 | 08:04 PM
nicknack25's Avatar
i would get a used tranny but i wouldn't know if that used tranny would have the same problem or anykind of problem until i put it in so i prefer a new one.
Old Nov 3, 2010 | 08:06 PM
nicknack25's Avatar
well when i jacked my car up, i pushed the axle up on accident because i was wiping the tranny down. i should probably check if it moves around while its on the ground huh? or would there be no difference?
Old Nov 3, 2010 | 08:12 PM
new tranny? for a 20 yr old civic? even rebuilding the one you have would cost too much
Old Nov 3, 2010 | 08:14 PM
nicknack25's Avatar
Oh yeah, forgot to mention that i have a b18a1 in my crx.
Old Nov 3, 2010 | 08:48 PM
new trans is still gonna cost too much..hell a rebuilt ls trans is like 450
Old Nov 3, 2010 | 09:21 PM
nicknack25's Avatar
But if i buy a used one, i never know if its gonna end up like the tranny i have now. If i get a new one, then i wont have to worry about much.
Old Nov 5, 2010 | 08:06 PM
well a new NEW trans is gonna cost proly 2k...if you really want to then rebuild the one you have. that way you know its good i guess
civicjoe8
Apr 11, 2006 08:52 PM
ALLINWONDER
Jan 17, 2006 06:00 AM
e jay one
Sep 11, 2005 07:49 AM
Jer'rome
Sep 30, 2004 06:14 PM
Bakeoff
Jun 2, 2002 09:19 PM
