harmonic balancer question
Several shops will cut the p/s belt section of an oem unit, then have it balanced. Much cheaper than an aftermarket unit and it is actually functional unlike those cheap billet pulleys.
so you're well informed before you decide what to use, here are some links to get you started.
ATI Super Damper
Fluidamper-Honda
ATI Super Damper
Fluidamper-Honda
i've seen some heated debates on this topic before so i won't go there. But i think most anyone can agree that running the OE pulley comes with the best piece of mind. If you want to better form your own opinion do some reading/research on what an engine damper does and what the difference between damping and balancing of an engine is. I think this is where a lot of the common misconceptions stem from.
