Need Help On GSR Build Up (Newb)
I have a gsr block that I am wanting to rebuild this winter. I recieved the block for free , took it apart and found it had eagle rods and srp pistons. The motor through a rod bearing , took the crank to the machine shop and he said it would need a nice amount of work. Also I took the rod that through the bearing to the machine shop and said the rod could be fixed.. My question is how would I go about getting the correct bearings.
Here is what im wanting to do with the motor
81.5 mm or 82 mm Bore
Wanting to get je or cp 11:5 to 1 compression pistons
Use my eagle rods I have or get a replacement rod for the one that through the bearing.
Blox Type B Cam Shafts with Dual Valve Springs
Tune on Hondata s200 or 300
Hy Tec Replica Header
And be able to shoot 100 shot of nitrous at the track.
Aem Wide Band
I already have Skunk 2 Pro Series Intake Manifold
Aem V2 Intake n Aem Fuel Rail
Any help would be appreciated would be my first build so I have a lot of ?s
Aem Wide Band
Id find yourself a friend that has done it before. Jus listening to a bunch of guys online tell you is a setup for disaster.
As for bearing measurements your gonna have to wait till the crank is done. If the crank didn't need work usually the bearings have the size on them stamped
