Brake Fluid Leak
I got a 89 civic and im seeing a slight brake fluid leak coming frm between the master cylinder and booster. Is there a gasket/seal that needs to be replaced to stop the leak?? and if there is, could this be the seal?
#9 in the illustration.
any input is appreciated.
Yes that is a seal, but that shouldn't cause your to see fluid, I think it is more of a dust seal. When you bench bleed the master cylinder off the car it doesn't leak fluid. I think you need a new MC or a rebuild kit.
ok but just to clarify what exactly is wrong with my master cylinder? seal on secondary piston? just want to know what caused the problem before i move onto fixing it
o and also is brake fluid leaking INTO the booster??? if it is what do i need to do about that... wouldnt think brake fluid is good for the diaphragm in booster.
thanks
thanks
thanks
thanks
Jim Pivonka
10
Aug 11, 2014 06:02 PM
stripes777
Aug 27, 2003 09:07 PM
