Up up up
Old Nov 3, 2010 | 09:32 AM
318's Avatar
318
Default Up up up
So I've got coilovers on my EF hatch, and I live where it snows. Right now my Honda is sitting about 8 inches off the ground. How high can I raise my coilovers while still keeping my axles happy? Is there a point where there would be to much angle on the CV joints that may cause them to wear abnormally or fail? I won't drive it that much in the winter since I've got a beater pickup to drive, but I think it'd be funny to see a 4x4 stanced EF hatch.
Thanks,
Sawyer
Old Nov 3, 2010 | 09:43 AM
alex14's Avatar
Default Re: Up up up
Depends on what shock/coliovers you have. only way to know for sure is to just do it. compare your height to a stock civic and go from there.
Old Nov 3, 2010 | 10:23 AM
318's Avatar
318
They're Function and Form stage 1. I just want to know if there's a certain angle that the CV joints will not like.
Old Nov 3, 2010 | 10:48 AM
pimpwagon's Avatar
The more angle to them the weaker they become. They don't have a specific point of no return. if you were to use a longer suspension arm that allowed for a longer axle, you wouldnt have such a drastic angle. if you made custom motor and tranny mounts to drop the axles to the hubs height, you could space everything else down and achieve your desired.
Old Nov 3, 2010 | 10:53 AM
318's Avatar
318
So if I don't launch it or drive hard while its up in the air I should be fine? I'd be hard pressed to put that much work into it with no shop and it only being in this configuration for a few months.
Old Nov 3, 2010 | 11:24 AM
pimpwagon's Avatar
best thing to do would be to separate an old axle and see from the inside how far you can go. i had no trouble with my 4runner when i cranked down the torsion bars and put my axles at a larger angle, i dont know how far an ef can go, so thats why i'm attempting to slap atv tires on my hatch and make a run in the snow.
Sunkenkarma
Sep 19, 2017 10:01 PM
Toe_fur
10
Jun 9, 2013 03:10 PM
Antyon
Aug 25, 2009 04:47 PM
Josh C.
47
Jul 6, 2008 08:38 PM
Ministry
Jul 1, 2004 11:22 AM
