ring gaps.
Old Nov 3, 2010 | 09:13 AM
thegatekeeper14's Avatar
Default ring gaps.
well ive tried searching and i come up with nothing but diffrent people claiming there right.
so i wanna see what you guys think about ring gaps.
im building a na d series at the stock bore.
but what im really looking for is the most comon used equation for finding out the ring gaps for both FI and NA.
and while were at it. whats a desired piston to wall clearence for both na and FI?
Old Nov 3, 2010 | 10:37 AM
EG1834's Avatar
Default Re: ring gaps.
Ring gaps and piston-wall clearance don't really follow a "one size fits all" rule. Obviously the clearances will vary depending on being NA or under Forced Induction (to include nitrous), but also materials, design, and intended use.
Cast pistons usually allow a tighter clearance (~.0005-.002") than a forged piston, and even with forged pistons you have a 4032 alloy which usually allows a tighter clearance (~.002-.004") than a 2618 alloy (~.003-.006"). Rings gaps are the same way as you have to consider not only the material of the ring, but also how much heat and cylinder pressure it will be exposed to as well as how far up the piston the ring is placed in proximity to said combustion heat.
Luckily, the manufacturers of said parts usually know their **** and include recommended clearances for the ring gaps as well as piston-wall. I've always followed those recommendations and I've never had a reason to regret it.
Old Nov 3, 2010 | 10:43 AM
well lets say for an oem rebuild im using oem pistons and rings.
Old Nov 3, 2010 | 11:11 AM
EG1834's Avatar
Go with OEM specs. That's what they're for.
Old Nov 3, 2010 | 01:59 PM
any clue as to what that is?
Old Nov 3, 2010 | 02:13 PM
d112crzy's Avatar
Buy a manual.
Old Nov 3, 2010 | 02:21 PM
EG1834's Avatar
Not off the top of my head, but I'm sure someone has a service manual with those specifications. You may be able to find it if you try Google.
Old Nov 3, 2010 | 03:30 PM
BadWay's Avatar
as per 1994 honda civic factory service manual
piston to bore .0004 - .0016 new, .002 service limit
ring gap top .006 - .012, .024 service limit
second .012 - .018, .028 service limit
oil ring d16z .008 - .028, .031 service limit
(all sizes are in inches)
Old Nov 3, 2010 | 03:59 PM
thank you badway
Old Nov 4, 2010 | 12:22 PM
Chiovnidca's Avatar
I usually go with what the piston ring manufacturer recommends.
Old Jan 18, 2011 | 02:14 PM
Si Integra's Avatar
First let me start by saying I have searched and read dozens of threads here and on other sites for the past few days before posting.
If you can help, I am Looking for a little advise. After melting a piston several years ago from what I believe to be a bad tune, I am finally getting around to rebuilding my engine. I ordered new pistons/rings etc. The block was machined and honed to the pistons. The problem I have is after reading countless threads and talking to JE I am torn on the #2 piston ring end gap. When I received the rings, 2 of them were substantially larger than the other two. Resulting in an end gap of .028 in 2 cylinders for the 2nd ring. The other two are sitting at .021 and .022
I talked to 2 different people at JE and they keep telling me the #2 piston ring gap makes no difference as long as the end gap is large enough to avoid butting. They told me that they do not manufacture them and the manufacturer has a tolerance of .010 I believe is the number they through out.
If this were the case, why in both their literature and what I see online do most people suggest a clearance of .022 for the second ring.
I would really appreciate any advise.
The engine is tuned to 20psi and was making about 400whp on pump gas. Its bored 81.50 and honed just a tad looser.
I have searched countless threads with nothing that was a concrete explanation for this. I hate to rebuild just to destroy another engine over something so trivial.
Thanks for any help you may have!
Old Jan 18, 2011 | 03:22 PM
d112crzy's Avatar
Just put them all to .028.
Old Jan 18, 2011 | 04:18 PM
Si Integra's Avatar
Yeah, that seems to be the logical way to proceed, but I am looking for a concrete answer as to why its ok to go larger and what effects may result from doing so.
ZCHondaCRX91
Engine Machining & Assembly
Feb 12, 2019 02:43 AM
5_Lug_B
Aug 5, 2007 09:26 PM
95blackEG
May 23, 2007 02:50 PM
MatHadder
Nov 19, 2006 11:04 AM
Yambor
Apr 29, 2005 10:55 PM
