wont crank
I have a 2000 accord that will not crank. it reads 11.6v and when i turn the key to the second position to turn on the fuel pump it gets 9.7v, not enough to turn the starter...i already clean all the grounds (the ones i can see) and still no crank. PLEASE HELP
Ok so i jumped it and i was looking at the multimeter and while i was jumping it was at 14.1v and i the the ignition to the second position (KOEO) it dropped to 12v and i got it to turn on, but why would it drop 2v when i turn the ignition to the 2 position???
sounds like you have a couple of bad cells in both batteries try a battery that you have in another car that you know is in good working condition see if you still have the same results.. that kind of drop off could also be bad connection from the battery terminals also make sure you get a battery post/terminal cleaner the brush type..
xEJFDMx
18
Dec 18, 2006 02:21 PM
thanks for the help
