help me fix my tach plz!
Old Nov 2, 2010 | 06:55 AM
efjones9's Avatar
Default help me fix my tach plz!
It happend when I changed my headgasket about a year and a half ago. It was working b4 I swapped the headgasket so idk wat tha problem is! Is there a fuse that's hidden that I should check? I tested everything from the ecu output to switching switching ecu cluster and distributor. I was thinking about just running a straight wire to the cluster from the ecu. Would that work?
Old Nov 2, 2010 | 07:10 AM
slywfbpsi's Avatar
Default Re: help me fix my tach plz!
check the blue wire coming from dizzy.
Old Nov 2, 2010 | 07:37 AM
efjones9's Avatar
What would I check 4? Voltage?
Old Nov 2, 2010 | 07:47 AM
slywfbpsi's Avatar
That or make sure you didn't snag the wire when you changed the headgasket.
DeeJaaY209
Sep 19, 2013 01:27 AM
vtechjunkie
28
Mar 16, 2010 11:14 AM
Firefoxracer
Nov 22, 2006 01:32 PM
b20guy
Apr 11, 2003 05:12 PM
Steve91
Feb 10, 2003 07:46 AM
