Skunk2 Adjustable Coil overs?
I found skunk2 coil overs on www.thmotorsports.com but there just the sleeves and here the link to let you know that I mean http://thmotorsports.com/skunk2/skun...s/g-50688.aspx
would i need ajustable shocks to complete it and i know im gonna need camberkit but just saying if i but this skunk2 and adjustable shock would i be good?
serious advice no bullshitting comment
If you're gonna waste your time with coilover "sleeves" from Skunk2 just use them on stock struts, the ride won't be great either way so just go for it. Also, read up on the thread titled something along the lines of "you do not need a camber kit".
I have them, and i will be switching out to koni/gc or amr setup.
I highly suggest steping up to the ground control coilovers.
I am currently on stock shocks as well, as long as you arent slammed and arent runing high spring rates the ride wont be horrible. However everyones deffinetion of ride quality is different.
PinoyCivic
May 24, 2006 12:10 PM
adjustable, adjustible, ajustedbal, ajustible, coil, coilohow, coilovers, coils, honda, lower, prelude, skunk2, sleeves, stock, struts
