Power steering fail
I searched and didn't find what I was looking for. I have an 01 ITR with 119k miles on it and all of a sudden i lost 85% power steering. When I turn the wheel the belt squeals and the pulley looks like it's having a hard time turning but it turns fine when not turning the wheel. Is this a power steering pump failure or something else?? Need some answers asap! Thanks
sounds like pump may have gone bad, it mean time take off the belt and you can drive till get pump rebuilt or replaced
rebuild kit components is only like $30
http://www.acuraoemparts.com/delray/...All&vinsrch=no
get all new gaskets and o-rings listed and the bearing
91347-PAA-A01 O-RING (16.7X1.8) 1 2001 INTEGRA 0.72 0.54
91345-PAA-A01 O-RING (13.0X1.9) 1 2001 INTEGRA 0.63 0.47
91048-P2A-003 BEARING, RADIAL BALL (17X40X12) 12.30 9.23 <---MORE THEN LIKELY THATS WHAT WENT BAD
91249-P2A-003 SEAL, POWER STEERING PUMP 5.15 3.86
91347-P2A-003 O-RING (15.2X2.4) 1 2001 INTEGRA 0.47 0.35
91348-P2A-003 O-RING (51.0X2.4) 1 2001 INTEGRA 0.98 0.74
91349-P2A-003 SEAL, POWER STEERING PUMP COVER 1 2001 INTEGRA 6.90 5.18
I thought my pump went bad because the same thing happened to me, and a temp gun told me the pump was burning up. After changing it the same thing happened. It turns out that the high pressure line collapsed and clogged.
