Bout to order tires, what would u recommend?
Old Sep 20, 2002 | 08:23 PM
vtecdc2's Avatar
Default Bout to order tires, what would u recommend?
i'm about to order some new tires, but i dont know which size i should get.
205-45-16, or 215-40-16?
Old Sep 21, 2002 | 07:47 AM
94mugenintegra's Avatar
Default Re: Bout to order tires, what would u recommend? (VTECDC2)
215 might be too wide if your car is slammed.
But wither way i would go with a 40 profile.....
Old Sep 21, 2002 | 09:03 AM
jmaperformance's Avatar
Default Re: Bout to order tires, what would u recommend? (94mugenintegra)
My personal opinion would be the 205/40/16
That way you have fender clearance and the low profile look. But that's my 2 cents
Specially if you are running a 16x7 rim. The 215 would be too wide.
Marc
Old Sep 21, 2002 | 09:10 PM
vtecdc2's Avatar
Default Re: Bout to order tires, what would u recommend? (jmaperformance)
205-40-16 makes the wheels look tiny.. i rather have more rubber, than a overall small tire..
Old Sep 21, 2002 | 10:13 PM
smkngsr's Avatar
mine is actually 205-45-16...and look perfect...coz i u have 40 on 16's chances of u bending the wheels are big rather than getting 45's...u have more rubber for road clearance and smoother ride
Old Sep 21, 2002 | 11:35 PM
GSRrR's Avatar
Default Re: Bout to order tires, what would u recommend? (smkngsr)
voted for 205/45/16. Thanks is what I have and it is fine with me. With 215 your speedo will be more off too.
Old Sep 22, 2002 | 01:11 AM
SIK IN DA HED's Avatar
New User
Default Re: Bout to order tires, what would u recommend? (GSRrR)
stick to the 205 45 16s. 215s are too wide and 40s are too skinny.
Old Sep 22, 2002 | 08:15 AM
GSRaCeRbOI's Avatar
I voted 205/45/16.. thats what I have on my car which is lowered approx 2".. its pretty close to stock diameter so it won't throw your speedo off...abundant tire selection, doesn't rub a lot unless I'm doing really hard cornering or full lock to lock U turns...
zexifiedlude
Jan 26, 2006 03:29 PM
XX Boosted Si XX
Nov 28, 2005 07:46 AM
PA Geesir
May 3, 2004 04:58 PM
B16Drag
Jan 26, 2004 07:09 PM
-Gambit-
Nov 9, 2002 03:41 PM
