How do I correct my air/fuel mixture??
I installed a skunk2 manifold a while back on my gsr motor. Ever since my idle has sucked ***. I've adjusted the air fuel mixture screw thing but it's not really helping.
All I want is a consistant 750-800 rpm at idle.
I've heard that you disconnect the ecu/battery then unplug the IACV and all should be golden.
I did that and nothing...
So...there has to be something that I'm not doing. Any clue?
tia
tia
does the idle jump up and down or is it just really low? If its jumping up and down you have a vacum leak...check all the lines to make sure everything is tight.
jdm.ejone
Jun 15, 2008 04:50 PM
