Using a traction bar with stock crossmember?
Hey, I have a 88 CRX Si I recently bought and built from a guy who had it turbo.
He removed the stock cross member and was using a traction bar/radius rod package instead with custom brackets for the radiator.
I'm now running this setup, with a completely stock d16a6, solid engine/trans mounts on the side, stock rear mount, and no front mount.
The problem is that this is way too aggressive for a stock, daily driven crx. It vibrates my whole car and I'm trying to pass inspection.
I want to put the stock cross member back on, but lo and behold, the last owner completely cut out the front end. NO radiator support on the buttom.
What I wanted to know is if I can somehow keep the traction bar on the car to give extra support, and hold the radiator, but use the stock crossmember for the radius rods and front mount so I can go back to rubber mounts.
Is this possible? I haven't gotten down there to take measurements yet. I'd even consider keeping the radius rods on the traction bar if they will fit underneath the stock crossmember, or modifying the crossmember with a sawzaw to fit just so I can run that front mount and get rid of solid mounts.
Anyone done this?
Anyone done this?
Well, the traction bar on this car mounts into the 3 holes for the tow hooks... So the area for the stock crossmember is still available. I'm just worried about something hitting. I'll take some pics when I get a chance to give a better idea.
My original idea was to run the stock crossmember, and fab up a bar, similar to the traction bar to mount the radiator on, using the tow hook holes. But then I realized, maybe I can just use the traction bar for that, plus extra strength, instead of making something just like it...
you are wasting your time trying to come up with a subpar solution to a nonexistent problem.If you want a traction bar keep it. If you want a cross member put that on.
As I stated before, the radiator is currently braced by the traction bar. If that's removed, there is NOTHING to sit the radiator on, which is an issue.
My only other option is to buy a new bulkhead so that I have a radiator support/front end again, but I is broke.
So I either put the the stock cross member on and try to fab something to hold the radiator, or try to modify something to run both.
wow, just put the stock crossmember back on along with the stock radius rods the radiator will sit fine right on the crossmember, then bolt up your front motor mount from the transmission to the crossmember and it will be fine
If I put the stock cross member on, I have absolutely nothing to hold up the radiator. It's just air down there.
sounds like you have an innovative mounts crossmember. the one i have has spots where a half size rad would sit for clearance. seems he cut the 2 tabs off under the car that supports the rad?? maybe weld somethin on there? thats what id do..ive become a master rigging things to work lol
I like the idea of having the traction bar there for extra strength, so I'm going to see if I can make it all work together. If not, I'm going to remove the traction bar, install a stock crossmember, and fab up something to hold the radiator up, rather than "letting it sit on the crossmember."
One nice bump and my radiator will be hanging by the hoses haha.
But to the people saying "wow", and "simple solution"
I'm not a moron. I put the entire car together in less than a week with a full time job. I simply was asking if it's possible to fit both a traction bar and crossmember to solve my problem. Ya know, has anybody done this, since if it would work, it would be my best solution.
If I had to choose between stock crossmember, and a traction bar with solid engine/trans mounts, on a stock crx si, I'm gonna go with stock crossmember. If I want to become a race-car driver on the streets of Philadelphia, I'll keep the unnecessary piece of metal on my car, preventing me from having a nice, quiet ride, and a perfectly seated radiator.
I'm going to venture and say the traction bar is NOT causing vibrations, the motor mount inserts from the last guy are probably still in there and causing the vibrations.
The solid engine and trans mounts are whats causing the vibrations, but I'm trying to find a way to use the traction bar and crossmember if anybody knows, or just crossmember and custom fabbed mounts for my radiator, because the original owner hacked up the front end for an intercooler.
acmoc
11
Apr 5, 2010 04:05 PM
gnar kill
Nov 14, 2007 08:54 AM
crxmadness
12
Jun 22, 2006 04:18 AM
yellowrexsi
Mar 27, 2006 04:22 AM
