Honda S2000 Honda S2000
ABS light
Old Oct 30, 2010 | 02:01 AM
civ_tek's Avatar
Icon2 ABS light
Sorry did a search but nothing came up..
This happened a few days ago, i been working 12 hours shifts so i havent had time to look into it yet, but maybe someone can help me out. Every now and then my ABS lights comes on right when u start up the car.. some times it comes on during a drive and stay on until the next start up... but here's the strange part.. when ever my ABS light comes on, my heater/ac turns off, and the side mirrors wont adjust.. have anyone experience this problem before?
Old Nov 1, 2010 | 09:31 PM
civ_tek's Avatar
Default Re: ABS light
bump.. anyone?
Old May 10, 2011 | 12:09 PM
ThePizzaMan's Avatar
Bump. Same issue. ABS light ON, Air Con OFF. Intermittent.
Old May 11, 2011 | 11:22 AM
rufus2008's Avatar
When my trunk light when out the other day I threw the R/C Mirror fuse into it's place for the day. Low and behold the ABS light came on. So they're on the same circuit. New fuse and the light is gone now. However, I'm certain the AC still worked. Sounds like a short, which I'd much rather have than ABS failure.
Old May 11, 2011 | 11:43 AM
ReddotsS2K's Avatar
Check all your fuses for sure. I had a right rear sensor go bad but i don't recall the a/c not working. Is your abs engaging?
Old May 11, 2011 | 06:14 PM
marshman's Avatar
my abs light comes on about 1/2 the time i'm driving. sometimes it goes off but it usually stays on once it comes on. usually it's triggered by a bump going onto or off of a bridge. abs still seems to work but the light is getting annoying.
edit: but my a/c and heat remain working regardless
Old May 12, 2011 | 04:29 AM
ReddotsS2K's Avatar
Sounds like a short or something. The only way i know of fixing this would be to have honda hook it up to their computer to diagnose where the problem is.
Old May 13, 2011 | 08:12 AM
nguyennamc's Avatar
process of elimination? i suggest, check fuses, get it diagnosed as stated before, and check and make sure all your abs sensors wires arent cut, and check the abs sensors one by one. hope this helps.
Old May 14, 2011 | 11:12 AM
Tony Two tribes's Avatar
My 05 Mugen S2000 does exactly the same thing (why i found this Forum/link-I am not alone!). Usually from first switch on, not every time. Pulled fuses but who knows will have to get the dealer to check. If it dosn't reset I usually pull over and switch off/restart and it works.
Abs light comes on goes off (but actuallt ABS still working) occasionally the AC and all heater switch actions don't work then reboot.
Hell i brought it for the 278BHP its kicking so will live with it for a while.
Old Feb 14, 2012 | 02:45 AM
civ_tek's Avatar
Did you get your problem fix Tony Two tribes?
gregd101
Honda CR-V & Element
May 29, 2011 03:11 PM
komat
Oct 8, 2010 05:37 AM
Scither69
Jun 9, 2004 09:19 PM
Lost Type R
Mar 22, 2003 07:32 PM
