Changing transmission oil??
Old Sep 20, 2002 | 05:47 PM
Mires's Avatar
Default Changing transmission oil??
I havent changed it yet and frankly not sure how. Thanx for the help.
Old Sep 20, 2002 | 05:54 PM
Greg900rr's Avatar
Default Re: Changing transmission oil?? (ITR-862)
I think you should let a dealer do it.
Old Sep 20, 2002 | 06:11 PM
jonas's Avatar
http://www.c-speedracing.com/howto/t...ransfluid.html
Old Sep 20, 2002 | 06:36 PM
Honda F1's Avatar
Default Re: Changing transmission oil?? (jonas)
Basically if you can change your engine oil, you can change your transmission fluid. You just need a long funnel and be sure that your car is on level ground.
Old Sep 20, 2002 | 06:57 PM
Dr Pooface's Avatar
Default Re: Changing transmission oil?? (Honda F1)
start
open fill plug
open drain plug
let all the oil drain out
replace the drain plug
fill it until it spills out the fill plug
replace the fill plug
done
Old Sep 20, 2002 | 07:04 PM
Mires's Avatar
Default Re: Changing transmission oil?? (Ddub)
Where is the fill plug and the drain plug???
Old Sep 20, 2002 | 07:08 PM
Mires's Avatar
Nevermind, all i needed to do is check the link. Now have a few
Old Sep 21, 2002 | 08:16 AM
Ibuprofen's Avatar
you can actually just reach in with a hose from the engine bay on top to fill the oil up if you have long enough arms..
B2AutoDesigns
Performance
36
Mar 14, 2012 12:00 PM
vannak_5415
Oct 6, 2008 05:34 PM
vics_si
Aug 4, 2005 04:47 PM
B1TEM3
16
Feb 18, 2004 03:07 PM
