b16a Shift linkage bolt (on transmission)?
i couldnt find anything on this but im sure someone would be able to clear this up for me really quick!
the big round shifter bushing that is on the shift linkage that is bolted to the transmission, as i removed the bolt, transmission fluid starting pouring out! is this normal? the transmission fluid started gushing out like if it was a drain plug or something. I just want to know if thats normal or if something is wrong there. Thanks guys!
thats all bad man, somebody probably put a bolt that was 2 long or didnt belong there, no bueno fluid should not be coming outta there EVER
yeah, pretty much looks like it. used some gray silicon, sealed it up once i put the the new shifter bushing. doest leak, all is good ! :D
allmotorls95
Sep 10, 2002 09:00 AM
